Best MOA 1;10 scale Axles
Hi guys. I'm looking for some 1;10 scale MOA's i want to run 2.2's. Any one have some good suggestions. Building a rather large military style vehicle so the MOA's would work quite well for it.
RE: Best MOA 1;10 scale Axles
the XR10 axles from axial would be the ideal ones. tough, slim and high quality.
might set you back a pretty penny tho.
you might be able to get a used redcat RS10 XT for pretty cheap and use the axles from it. they are much bulkier by also cheaper.
I like the Axial and bully's but yeah they are pricey.I am completely new at trucks and crawlers, I do RC tanks and have some pretty expensive ones but even some of our high quality parts arent as expensive as the stuff you guys use. I have been checking out some of the custom builds and they are works of art.
I think the Axials will probably be the less painfull way to go. I also need to keep the tires right around 3.5 to 4 inches if possible to keep to the scale I'm trying to work to. the 1;16 tanks just dont match up scale wise with anything in the RC truck hobby but 1;10 from whati have seen can be doable for the vehicle i plan to build.
