Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Rock Crawlers
 Strongest solid axles for a crawler >
RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
Old 01-27-2005 | 08:44 PM
Johnny Ripper's Avatar
Default Strongest solid axles for a crawler
I have been looking around for some strong sloid axles for my crawler project. I have been looking at some x-factor axles. They look like the best ones I can find for now. Is there any aluminum or steel axles avalible?
Old 01-27-2005 | 09:19 PM
Default RE: Strongest solid axles for a crawler
The TLT-1 axles are all steel.
Old 01-27-2005 | 09:24 PM
What! [X(] do you got any pictures?
Old 01-27-2005 | 09:41 PM
They're steel inside...and I'm not going to take them apart for you.
Were you looking for axles that are steel on the outside as well? Traditionally, when someone says axle (at least in the rull scale off road world), they are takling about the inside.
Old 01-27-2005 | 10:12 PM
shortbusjeep's Avatar
if you want a full metal "axle" in cluding the axle houseing and shafts and gears it would be about 700 to 900 depending where you got them
there is a guy on here who quoted me 799 for a set of shaft driven built to my specifications
metal axles housings are not needed i dont think ant one has ever broken an axle housing and i bet qaxle shafts havent even been broken
sbj
Old 01-27-2005 | 10:25 PM
How wide are TLT-1 axles? I'm planning on building an 1/8 scale crawler. Would it be difficult to mount HPI savage shocks to those tlt-1 axles? Would it be difficult to mount savage drive line cups to the pinnion shafts? I have lots of broken drivelines and could weld some up for a custom fit.
I'm kind of a noob to the crawling scene. I own 2 savages, 2 t-maxxes, and one lst, but no crawlers.
Old 01-27-2005 | 10:33 PM
tlts are 1:18
Old 01-27-2005 | 10:36 PM
What woud be the best 1/10 or 1/8 scale axles? (strongest)
Old 01-27-2005 | 11:04 PM
garynjr's Avatar
Are you lookig for Shaft driven or independent?
Clods are probably the best independant motor axels. They are very beafy. and can easily be used on an 1/8th scale truck.
These are Shaft drien... TXT and twin force axles are larger then the TLT axles and are about the same size as the Clods. TLT axles are great but in my opinion a little small (Narrow) to pull off a nice looking 1/8th scale. I can practially fit my TLT between the wheel base of my clod.
Hope that helps...
Old 01-28-2005 | 12:42 AM
How much would two clod axles run me new or used?
Old 01-28-2005 | 12:49 AM
garynjr's Avatar
Used, Hard to find but I've seen them for around $130
New Clod $200 at tower today! Plus you get a ton of screws and such and the wheels and tires...
Old 01-28-2005 | 01:35 AM
If you could get a link or part number that would be cool.
Old 01-28-2005 | 02:42 AM
Dose anyone know where I could get a hold of some mad force axles?
Old 01-28-2005 | 09:39 AM
garynjr's Avatar
There are many part numbers for the clod axles... It would be more expensive to order them in pieces then the whold truck...
And the only place I know of to get axles alone is e-bay...
Old 01-28-2005 | 10:09 AM
ORIGINAL: Bash Master
Try item 5952046947 at ebay
http://www.rcuniverse.com/market/item.cfm?itemId=73211
http://www.rcuniverse.com/market/item.cfm?itemId=69362
Old 01-28-2005 | 01:44 PM
I think I'm going with mad force axles. I may possibly use a .40 four stroke engine for this project. Dose anyone have a link or part number for some mad force axles?
Old 01-28-2005 | 05:40 PM
garynjr's Avatar
I wouldn't recomend nitro for crawling. Not that it can't be done but because of the SLOW and tecnical nature of crawling, nitro would be a serious pain. You will go through clutches like crazy and likely stahl a lot! Electric is nice because it's much more controlable at really low speed and it also can't stall out on you like nitro will. Just my thoughts...
Old 01-28-2005 | 06:36 PM
as are mine electric is much easyer, i tried a nitro crawler and not only is the cluch a pain but the delay between brake and gas lets you roll back on tough tech sections
just my opinion
it could be done but it is much more work
Old 01-28-2005 | 10:57 PM
I woud really like a part number for some mad force axles. Or a link where I can buy kyoso parts. I'm guessing that you cant get the axles complete. So would someone be nice enough to tell me what I need to buy to complete two mad force axles?
Old 01-28-2005 | 11:03 PM
garynjr's Avatar
Have you tried their web site? Usually manufacturers post the manual on the site and you could get it from there....
Old 01-28-2005 | 11:07 PM
Yeah, Ihave seen the manual on tower hobbies, but I would like a little list of the parts I need to complete two mad force axles. To be sure I get all the parts I need at the same time.
Old 01-28-2005 | 11:16 PM
garynjr's Avatar
I meant on their site not E-Bay. Not to buy the manual but to view it online... I'm not sure if tey have one or not. I know HPI posts all of their manuals in full on their site.
Old 01-28-2005 | 11:20 PM
lol, I was'nt looking to buy a manual, I was looking at it in adobe reader. I would like a little list of the parts I need to complete two mad force axles to be sure I get all the parts I need at the same time.
Old 01-28-2005 | 11:33 PM
garynjr's Avatar
Oh good. That's what I meant.
So it didn't have an exploded view huh. That sucks...
Old 01-29-2005 | 12:59 AM
These solid axles I'm trying to find are going to be put on a truck that I'm most likely going to be jumping really high. [sm=lol.gif]
