OFFICIAL WHEELY KING CRAWLER THREAD
#301
TX
RE: OFFICIAL WHEELY KING CRAWLER THREAD
Hey everyone I am buying a WK tomorrow and was wondering how much I can extend the wheelbase (I only want 11.5) without needing to get new driveshafts?
#302
ORIGINAL: learning2crawl
Dude,
How come you have the lower arms on the outside of the chassis? What I did when I stretched mine is get some 4/40 screws,lock nuts,aluminum tubing. Put the lower arms inside the chassis put screws in from outside through chassis than through lower arms top off with lock nut. After you have both sides done measure for the aluminum tubing from lock nut to lock nut.( dont trim down screws they will be covered by tubing) Cut tubing, back screws out place tubing in (get rid of the plastic spacer). It looks great and you don't have anything hanging off the side of the chassis. The E-Max body looks sweeet......... Check out the 72 chevy body by proline, they show it in the March 2008 issue,,,,swwwweeeetttttttt..........
Dude,
#303
ORIGINAL: vicious-peanut
ORIGINAL: s7jstep1
if you havent noticed, im a ford guy lol[8D]
The body does look nice though...
#305
TX
Well, I got my WK. I've been having a blast with it. The ESC seems to be a weak link however, with normal driving it doesn't get hot but with slow speed and alot of reverse and crawling it gets pretty hot huh?
#306
VA
The Wheely King is a great truck... Congrads...... Wait till you get some minor mod's....Awesome.... I fried my ESC within the first week...... I am now running the Rooster..... Going to convert over to brushless soon.... Again congrats and enjoy... Stock 1 st thing you can do with no cost is reverse tread pattern... Flip the tires around it will give it a better bite......
#307
TX
Yep, I flipped the front tires and removed the rear brace. Lifts that left front like crazy now! lol
The ESC thing seems common over on rccrawler too so when it goes I'll just get a waterproof one.
#308
Set up a little computer fan to blow on the ESC, that will stop it from shutting down and extend the life of the ESC by keeping it cooler.
Flipping the front tires may give it a little more traction, but in my opinion looks really dumb... I laugh every time I see it...
#310
MO
What ever you do don't try a 3 cell lipo on it because all your other batteries are dead and you still want to run. If you do you will probably experience magic smoke loss like I did.[X(]
#313
TX
Hell yea!! I found the body That I wanted to use form the start! the Proline muscle 2.0. Im still trying to figure out why they discontinued this body.
#315
Can anyone with a Wheely King please take a measurement for me. I want to know the width of a WK axle from stub axle to stub axle (see picture if you don't know what I mean)
MI
Has anyone ever built a four link suspension on their Wheely King Crawler? I Have my wheely King modified and I am still using the three link but would like to change to a four link but am not sure how to do it. Any advice?
#318
My first question is, Why? In the full size crawling world, the only reason (other than personal preference) to use a 4 link over a 3 link are strength and ease. A three link puts more stress on a single point of the axle than a 4 link does, and its easier to weld two brackets to an axle and use 2 straight upper links than it is to build a wishbone upper link. Look at the full size rock crawling world and you will see plenty of each. Those 2 problems (strength and ease of building) dont transfer down to rc scale, in fact at our scale its usually easier to build a proper 3 link than a 4 link. That's not to say that one is better than the other. Both can be equally good when properly set up. And thats the key, proper setup. A leaf spring setup will crawl better than a poorly setup link system.
A lot of people set up a "sort of" 4 link as seen in post 11 of this thread http://www.rcuniverse.com/forum/fb.asp?m=6028160 . Technically though this is still a 3 link, if a floppy one. A much better setup is the one seen in post 22, or just a rod extending the stock upper link, though this still allows a small amount more flex than a whole new solid upper arm. if you really really want a 4 link, you can do like in post 11 but rigidly attach the metal part the links are attached to to the axle rather than using the stock ball in the socket, or just remove the mount completely and fab up a new mount with points to mount two links, though doing so could make the situation worse by allowing flex. Also the further apart you mount the links, the less triangulation you have, less triangulation means a greater chance of the axle moving side to side. Think about this, you cant get more triangulated than a 3 link....
#319
MI
OK so maybe the four link is a bad idea then..... The other thing I was looking at was changing the shocks to one with a longer stroke and changing the mount location to get better travel. I have a set of shocks from my savage and was looking at using those. Good idea or bad? Also I have weighted my front tires using stick on airplane weights. I put 6 ounces in each front wheel is that enought or should I put in more?
#320
ORIGINAL: rc monkey
MI
ORIGINAL: rc monkey
Can someone help me please? I need to know how wide the axle is to see if I can use WK axles in a project.......
ORIGINAL: rc monkey
9-1/4" from outside of each stub axle. Give or take a very small amount.
#324
MD
thanks, i ordered mohabs, axial beedlocks, 15tpinion gear also to go with it... i was going to order the aluminum tubing from tower also but i figured it would be cheaper to use arrows... i already have tmaxx axels, and tmaxx rod ends..will tmaxx rod ends work?
#325
CA
Sounds good. You might look for a 96 t spur because the 15t pinion will not fit to the stock spur. Not enought adjustment slot available.
Sunny_B
Sunny_B
