Go Back  RCU Forums > RC Boats > RC Sailboats
 sail material >
sail material
RC Sailboats For all your r/c sailing needs, post here.
sail material
Old 07-30-2005 | 10:03 PM
marjin's Avatar
Default sail material
I am attempting to make a set of sails for a "Nirvana" by Megatech. Any info as to materials that can be used will be greatly appreciated.
Old 07-30-2005 | 11:05 PM
wismerhell's Avatar
Default RE: sail material
cheapest is probably the one you can get from a kite shop: icarex
a few others:
Mylar, Trispi aso...
Old 07-31-2005 | 11:33 AM
marjin's Avatar
wismerhell,
Thanks for the info, I'll give it a try. Does anyone use fabric material such as nylon or polyester?
marjin
Old 07-31-2005 | 05:43 PM
Well, if you know a sailmaker you may get some polyester very light cloth. Look for something like a "drifter" material which is usually pretty light. They would also have some spinnaker cloth which is nylon and quite light but stretches a lot.
Does anyone know a sailmaker for models? I have an old sailboat I would like to find material or a set of sails for also so if anyone has any good ideas, let us both know.
3dbob
Old 07-31-2005 | 08:25 PM
wismerhell's Avatar
http://www.carrsails.com/
though there are many others...
http://www.magicksails.com/
http://www.rc-yachts.com/index.htm
http://www.beanbag.com/wjsails/classes.htm
http://www.visionsails.com/index.php
Old 07-31-2005 | 10:18 PM
marjin's Avatar
3dbob,
Thanks, I'll try some of the ideas suggested. I have a lady friend, a superb seamstress, that is willing to tackle the job using the original sails for the patterns.
marjin
Old 08-01-2005 | 08:39 AM
ORIGINAL: marjin
3dbob,
marjin
Unless the sails are large (M-class, 10-Rater and beyond) sewing isn't the best way, usually only doublesided tape, as used by sailmakers, is sufficient.
I only zigzag the taped joints because I sail my boat in too much wind (or with too much sail) to keep the seams together.
The outside seams are just cut with a hot, sharpened soldering iron to stop it from fraying.
The more you sew, the more baggy your sails will end up...
Regards, Jan.
