Another newbie problem
CO
Hello all,
Was wondering if perhaps I could get alittle info from folks with expierencd with Thunder Tiger Victorias. See, I foolishly purchased one off ebay that arrived on my doorstep with: broken pieces, missing pieces and no directions. Was kind of hoping that somebaody could steer me in the direcion of obtaining replacement pieces and some directions. Any input is much appreciated. Thanks, Jeff
yellow,
I found alot of usefull info here http://www.victoriarc.org/building.htm
The step by step building guide has a bunch of info and pictures......
I dont have a victoria but I did get some ideas for another project of mine.
Hope it helps,
spin
Hope it helps,
spin
TX
If you were just wanting to make a boat out of it... then you might get skunked a little on the kit parts... otherwise... the only thing that you actually use from the kit is the hull, keel and rudder, the rest gets tossed. If you are planning building it as *just* a boat, check with your local sailing club or group (assuming you have one, and you probably do) and you may likely find someone has all the parts left over.
If you are building a competitive boat to race, then you have it all right there in the Vic Resource center. There are more add-ons, and go fast items than you can believe. Don't let it all fool you though... practice is the best add-on you can get. We had a guy in our club take someone's thown away sails.. literally wash the food off them from the trashcan they were in, and win the first 3 heats of a regatta a few weeks back, and against some Nationally ranked skippers. Never underestimate the importance of practice.
