Dave Johnson 1/4 scale Albatros DIII
#76
Thanks Barzini, I found the the article. It's for a 1/3 scale but it will come in handy.
I'm still investigating the engine. right now I am leaning towards a DLE 35A. Any thoughts ?
#77
I used the same engine recommended by the designer.A Cheetah 42.I just could not mount it upright and cut up my Mercedes D3 dummy engine.I dwelled on this for weeks than I saw Balsa U.S.A. came out with the 1/3 scale DVA and the engine was inverted! So I inverted mine and it worked out great!
#78
I have a DLE 35 R in my 1/4 DR1 tripe, and I think it is perfect in that plane. It is smaller than the DVII or the Albatros though.
Keep in mind, that these WW1 models like to have a bigger prop. It really has an effect when landing, as the extra air over the tail really help out on touchdown. The DLE 55 really improved the landings on my Fokker DVII. In fact, I was able to pull off a perfect 10 score on one of them at the AMA Nats this last summer. The engine had a lot to do with that, as much as that may surprise some.
In my opinion, you are better off to have a little more than you need than not enough. The 55cc will spin a 22"-23'" prop, while your 35 will be in the 19" range. That is a big difference.
#79
Take into consideration that the DIII has a narrow cowl and a 55 probably will not fit.My engine had a rear muffler which was a big plus.The 35 might be light and you will have to add weight to balance it.My 42 balanced the plane perfectly.It has a jump start on it so I do not have to use a starter.Where are you getting a spinner?
#80
VG, that's very interesting about the G38 in your D7. I had the same setup and it was perfect. I never flew at more than 1/2 throttle. In fact, i had my D7 set up to choke out the engine with full down throttle and down trim and if I was landing and forgot to trim down the throttle a little the plane would float and over shoot the runway. I like a little extra power as well.
barzini, I am going to investigate the Cheetah 42.
#81
