Reload this Page >
Pitts S1-S by EMHW
Pitts S1-S by EMHW
Old 03-22-2015, 01:22 PM
  #4651
acerc
acerc's Avatar
During the periods of waiting for glue to dry on the other Pitts I have been working on the canopy plug. It has been sanded to near perfection and then I coated it with a ceramic paint, actually 5 coats with light sanding in between. Now I need to put it in the oven and bake the paint a bit. I should get something pulled tomorrow.
Old 03-22-2015, 01:27 PM
  #4652
Melchizedek
Melchizedek's Avatar
Well wishes on the pull Robert.
Kevin
Old 03-23-2015, 05:55 AM
  #4653
FlyerInOKC
FlyerInOKC's Avatar
Robert I had a thought I would pass on. When I used Lexan for storm windows the one thing the guy at the plastic company recommended was using a type of washer with rubber on the inside to prevent stress cracks at the screw holes. I used these 4X4 sheets for 3 or 4 years taken them down and putting them back up several times a year. Over the course of that time I never developed a crack. Now I was using 3/16" think Lexan but it seems to me if you could get some thin rubber gasket material it might not be a bad idea to have a washer of that material under the screw heads. Good luck with the canopy!
Mike
Old 03-23-2015, 07:16 AM
  #4654
acerc
acerc's Avatar
I have washers with felt padding for just that. It's raining here today and with 100% humidity I am not even going to think about pulling a canopy.
Old 03-24-2015, 07:18 PM
  #4655
squirrly
How's the weather going to be for tomorrow? Are you going to try and pull a canopy?
Jeff
Old 03-25-2015, 11:53 AM
  #4656
acerc
acerc's Avatar
Sure, sooner or later. Probably get started on it tomorrow, was in no hurry whilst waiting for the plastic drill bit.
Old 03-26-2015, 07:27 AM
  #4657
acerc
acerc's Avatar
I have to be honest, I have been procrastinating getting started. The more I think about the plastics the more I know polycarbonate would be the best route. I have ordered a sheet and will pick it up tomorrow. When I return to the shop on Sunday my goal will be, exclusively, to finish this thing. So beginning Sunday I will post the progress of the canopy and framework, as well as the painting of the prop, also the assembly and installation of the figure. That will be my goal next week and for those that have been looking forward to the completion, sorry for the delays.
Old 03-26-2015, 07:41 AM
  #4658
squirrly
Hi Robert, your so close. Looking forward to it.
Jeff
Old 03-26-2015, 09:15 AM
  #4659
Melchizedek
No apologies necessary my friend.
Your the one producing. We armchair peanut gallery.
Its good to be a peanut in the gallery
Good luck with the polycarbonate.
Kevin
Old 03-29-2015, 11:44 AM
  #4660
acerc
acerc's Avatar
I spent a few hours running around all the hardware stores looking for a rheostat or even a lighting dimmer of enough watts. I am going to have to wait until the morning when the electrical supplies open to get something. In the mean time I have added the reinforcements inside the table. I also drilled the plastic for mounting in the frame and I am blown away at the difference in these drill bits. They cut through faster and extremely smoother than any other bit I have ever used, period. As it stands everything is prepped and ready for the oven to be readied. See ya's tomorrow.
Old 03-29-2015, 07:30 PM
  #4661
Cub Flyer Fresno
Cub Flyer Fresno's Avatar
Refresh my memory; what kind of drill bits did you get? (I'm too lazy to go back and read. )
Old 03-30-2015, 07:03 AM
  #4662
acerc
acerc's Avatar
Plastic bits have a different tip with 0° rake, works much better than standard bits.
I spent some time this morning running around the electric suppliers, apparently they don't really supply much. So I started shimming the plastic frame away from the oven until it holds at 250° and will leave it set for two hours. I will have to let it cool just long enough to wipe it again with a tak-rag before hitting the 340° vac temp. This is really warming the room up so I am also utilizing the vent system.
Old 03-30-2015, 09:12 AM
  #4663
acerc
acerc's Avatar
Well, I just made the first one, almost, everything went well right up to the point of removing it from the plug. The bright idea I had of coating the mold with a VHT ceramic paint, well, no so bright. The plastic stuck to the paint. So, I am off to Home Depot for another bag of Plaster and to begin again. Uhhhhhgg.
Old 03-30-2015, 09:14 AM
  #4664
FlyerInOKC
FlyerInOKC's Avatar
To paraphrase an old Hee Haw song: If it weren't for bad luck you'd have no luck at all!
Old 03-30-2015, 09:21 AM
  #4665
stevegauth30
stevegauth30's Avatar
The next one is it. I can feel it.
Old 03-30-2015, 11:32 AM
  #4666
acerc
acerc's Avatar
Well guys, I have kind of been playing with this until I know I can do the heating of the plastic right. With todays oven attempt with polycarbonate being a success I will order some proper mold making supplies. They are a bit expensive and needed to know before I went that way I could do it. I just poured another mold with the POP, it should be ready tomorrow. For now I am going to make one with the Plexiglas, it is by far the easiest to make and get this bird finished. I can make a really good one when the molding supplies come in, in a few weeks.
Old 03-30-2015, 11:36 AM
  #4667
acerc
acerc's Avatar
Just so everyone knows, I not only want to be able to pull a canopy but I want to be able to repeat it. I have, as of today, pulled two of different materials and can honestly say it is very repeatable. Reason being is I not only want this ability for myself but also to aid others in their search for a canopy, especially this airframe, I already have a couple guys wanting one as soon as I get it.
Old 03-30-2015, 11:53 AM
  #4668
stevegauth30
That's awesome. Guys like you make building that much easier for others who can't just make one. Good stuff. I'm thinking about going that route for my Mr. Mulligan wind screen. At least I can learn from your trials rather than my own. So thanks.
  #4669
stevegauth30
I owe you one. Lol
Old 03-31-2015, 09:10 AM
  #4670
raptureboy
raptureboy's Avatar
I believe there is a nice padded room waiting for you at your local mental health facility. LOL Not sure if I should call you persistant or just plain nuts!
Old 03-31-2015, 10:11 AM
  #4671
flyingagin
flyingagin's Avatar
Both
Ken
Old 03-31-2015, 11:01 AM
  #4672
acerc
acerc's Avatar
LOL! You guys are just as nuts as I. I said at the beginning of this I wanted to know how to do it, not just luck up and do one. I have learned about the plastic, experimented a bit with molding, and now I am ready to do it right. Like I said before, I always have this fear of screwing up when dealing with canopies and want to be able to make them myself. I will order the mold making supplies Thursday, but I will not be back until after next week. We are having a wedding at the house next week for my middle son so I have a lot of preparing of the house to do.
Old 03-31-2015, 11:17 AM
  #4673
Melchizedek
I, ll call robert exceptional. In the craftsman sence of the word.
He wants the result to be the best it can be. Almost a lost virtue.
Kevin
Old 03-31-2015, 11:56 AM
  #4674
flyingagin
flyingagin's Avatar
+ what Kevin said
Old 03-31-2015, 12:08 PM
  #4675
John_M_
John_M_'s Avatar
Good to hear about the lexan... this is just the learning phase... once you get a good working form, you'll have this one beat... form what I understand, a good hard plug, polished to as smooth as possible... maybe wipe it down with some hi temp silicon spray and buff it off; may help in pulling it off the plug.
I'm keeping a close eye on this one because your success will be my success nothing like learning from someone else's trials... notice I left the word "errors" out... there are no errors in research and development
John M,
