Reload this Page >
Building: Cosmic Wind - 1 / 2.6 scale
Old 11-29-2004, 04:00 PM
Laaars
Laaars's Avatar
Default RE: Building: Cosmic Wind - 1 / 2.6 scale
And the cockpit is ready for detaling, like seat, instruments (The instrument panel now is only temporarily), seat belts, stick, buttons, levers etc.
Some of the pictures also showing the neck-support wich was made from a balsa-cube.
And some pictures of the planes, like they are now.
ID:	197761   Click image for larger version
ID:	197762   Click image for larger version
ID:	197763   Click image for larger version
Old 12-18-2004, 01:46 PM
Laaars
Laaars's Avatar
Making air intakes:
Not so big interest for this it seems like, but I'll keep updating!
Now we have started to make the air intakes on the side.
First we draw the shape of the intakes on each side, to line ut the plywood-pieces we cut out before.
We had to make a little support because we haven't made the lower part of the nose yet. With a few adjustments it was good.
ID:	204284   Click image for larger version
ID:	204285   Click image for larger version
ID:	204286   Click image for larger version
Old 12-18-2004, 01:50 PM
Laaars
Laaars's Avatar
And now we have to shape the intakes around these pieces.
We use 100mm balsa, cut, glue, sand and shape. A lot of work, but it will be nice at the end.
This will only be applied at the front of the intake because it's very round, but at the rear we will cover it with thin balsa, and at the very end we will make a balsa block and sand it down to the right shape.
ID:	204288   Click image for larger version
ID:	204289   Click image for larger version
ID:	204290   Click image for larger version
Old 12-18-2004, 01:52 PM
Laaars
Laaars's Avatar
A few more pictures.
It rooms the cylinder head well, and it make a free airflow to the air intake on the engine.
The plan was also to have the muffler / silencer in the other side, but it isn't sure that it will fit, so we'll se about that.
ID:	204294   Click image for larger version
ID:	204295   Click image for larger version
ID:	204296   Click image for larger version
Old 01-01-2005, 08:35 AM
Stefan10
Hi Laaars, I am Stefan from Germany,
I found all the interesting pictures from your Cosmic production. I am very interesting to se the result because I am also in progress to build a Cosmic Wind. My scale is 1:3,3 and I am using a GFK body which I bought from a friend. He has the Main Modell to produce and sell them.
The wing measure is 180cm and I bought already a 26ccm MVVS engine.
What I would like to know from you or from your father is, how you will make the rudder and elevator in the back part. If it is possible for you to bring some informations in your productionstorry it will be very helpfuly for me.
Thanks and good luck
Stefan
Old 01-31-2005, 10:56 PM
  #31
GOGGLES PIZANO
hey guys! this is great.Laars hats off to you ! fantastic job.i ahve been looking for f-1 kits to build and found the selection very slim to none.i have a 3w-48-b2 gas engine i would love to stuff into such an airframesuch as these.the engine wieghs in at 4.6 pounds,9 inches cap to cap,rear intake.any info on 80 inchers or so ,i will be glad to hear about.keep up the good work laars. e\Elijah
Old 02-03-2005, 02:11 PM
  #32
Kellermann
Kellermann's Avatar
Hey Laaars,
you gotta get us some copies of these plans, even if they are rough sketches on paper. I usually work from the same kind of plans...
But I really look forward to build such a beautiful bird, in this very scale. I have several gas engines in the 30-45cc range laying around. Would be a nice fit into such a racer...
Please, what would it coost to Xerox the sketches of your father and send them to me in Brazil??
Marcus
Old 03-23-2005, 05:02 PM
  #33
Laaars
Laaars's Avatar
Thanks [8D]
About the plans, you have to ask my father.. will tell him this and you can talk to him!
Steffan, about the rudder: Do you mean how we built it? It was built by a frame of balsa, and the covered with a layer of thin balsa.
Well, here's some new pics... have done a lot since last time.
Here we have put in all the servos, and made the links to the rudder and elevators.
All the servos (Except for the throttle servo) are HS-635HB if I don't remember wrong.
ID:	248091   Click image for larger version
ID:	248092   Click image for larger version
ID:	248093   Click image for larger version
Old 03-23-2005, 05:06 PM
  #34
Laaars
Laaars's Avatar
And then it was time to make room for the muffler.
We had to make some changes in the front to make room for it, but it went okay.
We made a small "tunnel" for the muffler, to isolate the heat, and lead it to an air-vent we will have in the back...
And the we welded together some pipe-bends to make a nice exhaust pipe.
ID:	248099   Click image for larger version
ID:	248100   Click image for larger version
ID:	248101   Click image for larger version
Old 03-23-2005, 05:09 PM
  #35
Laaars
Laaars's Avatar
Some more pics...
You can see the finished exhaust pipe, and the muffler mounted with the pipe.
ID:	248107   Click image for larger version
ID:	248108   Click image for larger version
ID:	248109   Click image for larger version
Old 03-23-2005, 05:12 PM
  #36
Laaars
Laaars's Avatar
And even more pics... both exhaust systems are finished.
ID:	248112   Click image for larger version
ID:	248113   Click image for larger version
Old 03-24-2005, 01:44 PM
  #37
Stefan10
hi Laars,
that looks very good. I looked a lot of times on this page but nothing happend during the time. Maybe the winter in Norway was to warm
I finished my Cosmic completly but I did a big mistake. The weight is to high. So I start to produce new wings. There I did the mistake and I hope I can reduce the weight of 1kg.
You can take a look in my gallery there you can see some picture from my Cosmic Wind but the picture are not bran new.
So I will follow your side.
regards
Stefan
Old 03-24-2005, 02:23 PM
  #38
Trev
That's some very impressive work on the exhaust manifolds! Kinda makes me wish I could solder.
Everywhere I look it seems this skill at some point becomes indispensable for serious scale modelers.
Keep up the good work!
cheers,
Trev
Old 04-01-2005, 03:01 PM
  #39
tonyc
tonyc's Avatar
I like the way you did your exhaust. I am using a cannister muffler for the first time and you have shown me how to do mine.
thanks
tonyc
Old 05-16-2005, 08:33 AM
  #40
Laaars
Laaars's Avatar
Okay, time for some updates.
The exhaustpipes are finished, and we have made some "hatches" under the fuselage to the servo's and radio equipment.
And one of the air intakes are finished sanded down (At least mine are)
Here's some pics of the front with the hatch and everything in place
ID:	272184   Click image for larger version
ID:	272185   Click image for larger version
Old 05-16-2005, 08:36 AM
  #41
Laaars
Laaars's Avatar
Here's some pics of the rear hatch.
In this one sits all the servo's except for the throttle servo. And we will also have the radio equipment and battery down there.
There's also some pics of the rear wheel.
We have used a separate servo for this, and steel wire for linkage, with some springs in the end.
ID:	272187   Click image for larger version
ID:	272188   Click image for larger version
ID:	272189   Click image for larger version
Old 05-16-2005, 08:38 AM
  #42
Laaars
Laaars's Avatar
And some pics of the planes, as them stands today
ID:	272191   Click image for larger version
ID:	272192   Click image for larger version
Old 08-11-2005, 12:13 PM
  #43
Laaars
Laaars's Avatar
Time for some updates...
The fuselages is almost complete, except for the cockpit and some other things.
Have started on the wings... not so much to tell [8D]
ID:	308793   Click image for larger version
ID:	308794   Click image for larger version
Old 11-28-2005, 08:00 PM
  #44
Darrell B.
Darrell B.'s Avatar
Wonderful work!!!
Could you tell me where you purchased your spinners, and who makes them?
Darrell
Old 12-05-2005, 01:09 AM
  #45
peppern75
peppern75's Avatar
Hi
The spinners are from http://www.krumscheid-metallwaren.de...-englisch.html in Germany
The projects are slowly going forward, because we are building electric planes from ww1 in scale 1:12
http://home.no.net/flappen/prosjektsider/proj.htm
See more of my planes here: http://home.no.net/pernil
Old 02-23-2008, 11:59 AM
  #46
peppern75
peppern75's Avatar
Now started up the project again. Try to finish it this year.
Finish covering the fuselage, and started to paint it.
My home page:
http://home.no.net/pernil/
ID:	886321   Click image for larger version
ID:	886322   Click image for larger version
Old 02-23-2008, 01:12 PM
  #47
N1EDM
I'm glad that it's back. I'd been curious about the outcome of this project. Thanks for starting it up again,
Bob
Old 03-06-2008, 06:48 AM
  #48
Kellermann
Kellermann's Avatar
Beautiful, looks very good. Eager to see it finished, a pity you don't have plans to sell a copy...
Marcus
Old 03-06-2008, 08:11 AM
  #49
old git
Hi there,
I only just found this thread, very informative and the model looks superb.
Keep up the good work.
old git - - - - aka John L.
Old 03-07-2008, 08:28 AM
  #50
peppern75
peppern75's Avatar
Just a couple of new pictures
My home page: http://home.no.net/pernil
ID:	896933   Click image for larger version
ID:	896934   Click image for larger version
