 Spitfire question >
Spitfire question
Spitfire question
Old 04-11-2006 | 09:18 PM
Triple-A's Avatar
My Feedback: (93)
Default Spitfire question
I going to start working on a 1/5th spit. I'm going to do the clipped wing version and am wondering what to expect handling wise. Will losing that much wing area make a super HUGH differents? It's a Pica kit for what that's worth.
Bob
Old 04-11-2006 | 11:06 PM
Jimmbbo's Avatar
Default RE: Spitfire question
Would expect little difference... The wing loading will be marginally increased, as will the roll rate, but at model scale, power loading is soooo excessive that any adverse effects will be lost...
Cheers!
Jim
Old 04-11-2006 | 11:10 PM
Ed
Why would anyone want to ruin that beautiful elliptical wing [] , but no, it shouldn't make too much difference.
> Jim []
Old 04-12-2006 | 02:55 AM
Idigbo's Avatar
Completely agree with GeeBeeJim, I had a BT Mk14 with clipped wings, in Belgian colours, liked it on the ground, but once in the air, although it seemed to fly as well as the other full wing BT Spitfires I have had, it just didn't look right. After only a couple of weeks, I gave it tips, new ailerons and the other changes and turned it into this PR19. Back to looking good in the air too. I can confirm though, having flown the same model with and without tips, that there is not much difference, apart from the clipped version rolled quicker, or seemed to.
Ian.
ID:	443856   Click image for larger version
Old 04-12-2006 | 08:12 AM
rrudytoo's Avatar
My Feedback: (27)
Idigbo hit it right on the head regarding his description of the flight characteristics of the two wing forms. Supermarine clipped the Spit's wing to enhance low altitude maneuverability and in this they succeeded admirably. But, I have to agree with both Idigbo and GeeBee Jim that the clipped wing is esthectically the lesser of the two shapes. But, hey, that's just me.
Al
Old 04-12-2006 | 08:31 AM
My Feedback: (60)
Hey Bob, I like the clipped wing Spit myself and I'm a bona-fide Spitfire fanatic! Or maybe I'm just wierd? Either way, you're not alone. I say go for it!
Old 04-12-2006 | 09:49 AM
My Feedback: (59)
ORIGINAL: Chad Veich
clipped spitty's, pink spitty's, blue spitty's, he like em different as well
Old 04-12-2006 | 02:43 PM
My Feedback: (60)
ORIGINAL: t_burley
You got it Todd! One only has to look at my avatar to know I like them unique. Blue, clipped, and counter-rotaters too!
Old 04-12-2006 | 06:17 PM
Ed
Even Red > ( As long as the wing stays elliptical [>:] [:'(] [:@] )
Old 04-12-2006 | 07:35 PM
My Feedback: (15)
Another point, Pica kits tend to be on the heavy side when built. You may need all the wing area you can get. A little swiss cheesing on the non-critical areas can remedy this if you think it is worth the trouble. Paul
Old 04-12-2006 | 09:00 PM
Be sure you "cant" the gear forward about and inch or plan on never flying off grass. The Pica will NOT taxi on grass with the gear in the scale location. It will be immediately on it's nose.
Bish
Old 04-23-2006 | 10:40 PM
My Feedback: (28)
and.. keep the tail light, light, light..
Had to add close to 5 lbs of nose wt in mine !!!
Yikes.
Second the gear foward comment.
Flew fine for 5 years or so.. then.. well, nuf said.
grin.
