scale conversion >
scale conversion
scale conversion
Old 01-06-2003 | 02:54 AM
Rudeboy's Avatar
Default scale conversion
Am I correct when I assume that a 1/4 scale aircraft has 1/8 of the wing area of the real thing?
Can someone point me to some good info on topics as power for a given scale plane, predicting and calculating wing loading, and more of this stuff...?
Old 01-06-2003 | 04:38 PM
My Feedback: (37)
If I have a square that is 4 inches by 4 inches, then I have 16 square inches. 1/4 scale means linear reduction, so if each linear dimension ir reduced to 1/4 of its original dimension, it will be 1 inch by 1 inch, with an area of 1 square inch. A 1/4 scale has 1/16 of the wing surface area.
Good luck'
Old 01-06-2003 | 04:42 PM
Rudeboy's Avatar
Right...
When I look at it now I see I could have come up with that myself without bugging other people...
But thanks.
