Best scale photo!
#3526
RE: Best scale photo!
ORIGINAL: abufletcher
(When and were and whose, Frank?)
This is the Farman F22 scratchbuild for the Dutch foundation 'PHantasy in Blue' by Rie Jansen
Scale 1:5, Span: 3.12m, Length: 1.74m, Weight 10kg, Motor ZG23
Frank
#3531
The first two are my model, now being rebuilt! 110"' Laser 300 V 4c 50cc, 28lb
Third picture is the subject aircraft flying at Old Worden
#3532
A couple of pages ago I was rattling on about the 99% of so called "level" passes wheren't level passes at all.
Instead they were banked passes, the inboard wing being low... even though it appears that the aircraft is flying level to the ground. The first picture is a typical example.
If you've been loosing points during your straight and level pass at a competition,
that last picture is a BRILLIANT example of how a level pass should look.
#3533
Not quite sure what or why you are on about level pass, I was not trying to do one for the camera, just thought it was a nice 'scale' photo.
Anyway we abolished straight pass in comps last year.
If you want to see competition flying the European scale chomps takes place at Starmoen just 100k to the north of you in 12 DAYS time!
See you there? (find the Swordfish)
#3535
ORIGINAL: bokuda
...and it's sepia toned... []
That is absolutely perfect. No way at all to tell that isn't a real Farman and it's a great photo to boot! (When and were and whose, Frank?)
#3536
ORIGINAL: David Bathe
Gorgeous model, by the way, Richard! (I've seen the build thread over on RCSB.)
#3544
Hey Mike ( Lucky Dog ), re; Fokker D VI,It could almost pass for a fullsize replica......if only the builder had put the "N-struts" on correctly[X(]
I could be wrong but, I believe the middle strut of the "N" should connect the leading edge of the lower wing to trailing edge of the upper wing.
Oh-well.
Oh-well.
#3545
#3546
ORIGINAL: Lucky Dog
Nice. The Spit shot sure looks like typical English weather to me! Perhaps if you cropped out the tree with the Mig?
ORIGINAL: deckerv
couple more from the AMA District II fun fly that I thought looked like a pretty scale photo.
#3547
ORIGINAL: Spuetz
Yes, you're right. The struts need to be the other way around...
I could be wrong but, I believe the middle strut of the ''N'' should connect the leading edge of the lower wing to trailing edge of the upper wing.
