40 size zero kit ? >
40 size zero kit ?
40 size zero kit ?
Old 05-17-2003 | 09:16 PM
torp's Avatar
Default 40 size zero kit ?
Does anyone know where to get a good 40 size zero kit
that flys well ??
thanks
Old 05-18-2003 | 02:21 AM
WMB
Default Midwest Zero
I just started building a Midwest Zero today. I see them on Ebay sometimes. Mike
Old 05-18-2003 | 06:55 PM
WING Manufacturing is back in bussisness, they were at the Toledo show last month. They carry a Sport-Scale Short Kit (wood pack optional) of the M6M2. They also carry a Scale versions (foam wings, cowling, and plans only). I have the scale version and it's a great flying model. Very fast and unforgiving with a .46 to .50 size engine.
Old 05-19-2003 | 05:00 AM
EZ Zero 45
Old 05-20-2003 | 05:10 PM
Default zero
Kyosho has a arf zero 40 size,with a fiber glas fuselage.
With a ys 53 forestroke it flew perfect.
Old 12-21-2003 | 11:50 AM
Default RE: <span class=
The Midwest Zero is 'Stand Really far off' scale. Its a sport plane dressed up to resemble a Zero.
If you're interested in something much closer to scale check out the Marutaka Zero with the 58" span. I have their larger Zero (and a couple others) and these kits are quite accurate to scale and good fliers. However they are builders kits and not for a beginner. You'd want 3-4 kits under your belt before tackling one of these. Its available at www.hobbybarn.com for $169.
Old 12-23-2003 | 08:04 PM
You might want to try the new ZERO model by Seagull, from Horizon Hobby. This is a realy nice A.R.F.
Old 01-05-2004 | 03:40 PM
I just finished my Kyosho Zero ARF 40. I did not install retracts. I am concerned with the CG. The manual says that the model should weigh in at 5.7 lbs and it did. However, I had to add 8 oz of led to the front because the model was tail heavy. My guess is that the 8 oz of led is needed to make up for the missing retracts and extra servo. Has anybody had this problem?
