Best balsa stripper?
RE: Best balsa stripper?
i've never used anything as simple as this: http://www.balsatools.co.uk/#/ultima...per/4569638255
Only had it a few weeks from a friend at the flying club but it is brilliant.
I am trying to figure out what does the cutting? looking at that picture I am guessing you hold an exacto knife down thru the slot? That doesn't seem like it would be accurate, is there a trick I am not seeing?
It looks like a great tool for big jobs. The Master Airscrew Stripper is great from small stuff like rib caps, but not very effective for something like cutting 1/4 square longerons. This tool, however, looks like it could handle this. Am I correct in assuming that you buy only the metal part and have to build your own mounting board?
#31
FL
the longer bed looks like it makes it easier to keep along the fence, but still looks like you have to push much harder than i would imagine, the master airscew although far from perfect is pretty darn good! don't even get the one i made out any more! gave up on it.
