Reload this Page >
TA 152H Meister Scale Project Grun 4
Old 09-19-2012, 10:12 AM
  #851
David010567
David010567's Avatar
Default RE: TA 152H Meister Scale Project Grun 4
FYI... 30mm edf unit would fit nicely.
Old 09-19-2012, 07:09 PM
  #852
pandissix
My Feedback: (134)
pandissix's Avatar
I've used PC fans from radio shack anywhere from 2-3.5 inches. Can even run them off a separate ESC. May work.
Old 09-20-2012, 02:17 PM
  #853
IL2windhawk
Yeah, I've experimented with PC fans too, but they've never actually flown in any of my planes (or cooling EDFs, for that matter). As an alternate approach: you don't even need an ESC... you can run them with direct current from a seperate battery pack (Small LiPo, NiMH, NiCD, even Duracells) with an on/off switch inside the battery hatch. Or getting more fancy: a remote toggle switch tied to a channel on your TX. I get a little nervous about adding extra circuits to my flight LiPos, but that's probably just because I don't know jack about electricity!
Should be interesting!
Old 09-20-2012, 06:03 PM
  #854
David010567
Final sanded the Rudder until I was happy with it, then covered in fabric... Ready for dope and primer.
ID:	1803393   Click image for larger version
ID:	1803394   Click image for larger version
Old 09-21-2012, 06:22 AM
  #855
IL2windhawk
Beautiful! I like the trick with the removable hinge wire.
Old 09-21-2012, 08:24 AM
  #856
David010567
ORIGINAL: IL2windhawk
Thanks... We needed the rudder to be removable to get to the tail wheel retract mounting bolts through a small hole in the fin post. Now that I think about it... It will also be very handy to maintain the rudder pull-pull cables and rudder horn if something breaks or wears out.
Old 09-21-2012, 11:49 AM
  #857
David010567
Final sanded the Elevators and covered with fabric... Ready for dope and primer.
ID:	1803577   Click image for larger version
Old 09-21-2012, 11:52 AM
  #858
David010567
(4) magnets installed in the battery hatch using JB Weld.
Old 09-21-2012, 03:06 PM
  #859
vertical grimmace
vertical grimmace's Avatar
You guys coming to Warbirds over the Rockies next weekend?
Old 09-23-2012, 10:47 AM
  #860
David010567
Per the Obberkommando... (1) big smiley face opening through the firewall to vent the ESC + (1) hole to route the wiring to the battery compartment.
Old 09-23-2012, 10:50 AM
  #861
David010567
Feeling real good about this battery hatch now that all the magnets are installed and everything sanded flush. No way this thing is coming off.
As far as I'm concerned... The Electron conversion is now complete.
ID:	1804123   Click image for larger version
ID:	1804124   Click image for larger version
ID:	1804125   Click image for larger version
Old 09-23-2012, 10:51 AM
  #862
David010567
Glassed the fin joint and fin post... more glassing to come.
Old 09-23-2012, 01:59 PM
  #863
pandissix
My Feedback: (134)
pandissix's Avatar
Looks good DD super clean. What are you going to make the little snorkel thing for the hatch out of?
Thinking this thing could clear your bench soon?
Old 09-23-2012, 02:22 PM
  #864
David010567
I'm going to hand carve the snorkel that will be used for opening the hatch from hard wood like pine or something.
Old 09-24-2012, 11:35 AM
  #865
David010567
Turbo Charger... Here we go!!
Made a card board template for the outer blending lines. After locating the scoop, I put a 2" diameter hole in side of fuse for a future battery cooling fan and epoxied the fiberglass turbo scoop down.
ID:	1804529   Click image for larger version
ID:	1804530   Click image for larger version
ID:	1804531   Click image for larger version
Old 09-24-2012, 12:20 PM
  #866
David010567
Sanding mask made from template and located around Turbo scoop. Ready for "The Butter"
ID:	1804548   Click image for larger version
Old 09-24-2012, 12:34 PM
  #867
David010567
Just had a sick feeling I put this thing on the wrong side. Whew!
Old 09-24-2012, 12:38 PM
  #868
David010567
For some reason I chuckled when I saw this...
Old 09-24-2012, 04:52 PM
  #869
pandissix
My Feedback: (134)
pandissix's Avatar
Looks good. Glad you suggested the functional turbo scoop. We smoked two 6s packs in the 100+ heat this weekend...so any little bit well help!
What's with the radio? Is that part of the zombie apocalypse bail out kit?
Old 09-24-2012, 06:12 PM
  #870
David010567
ORIGINAL: pandissix
It's a Kraft radio... Get it?? Ahhhh never mind.
Old 09-25-2012, 08:28 AM
  #871
David010567
Just like buttering pancakes...
ID:	1804793   Click image for larger version
Old 09-25-2012, 04:41 PM
  #872
David010567
Here's my list of required tools... Gotta get after this Turbo scoop... Geez... Pandi never visits me on days like this.
ID:	1804965   Click image for larger version
Old 09-25-2012, 07:03 PM
  #873
pandissix
My Feedback: (134)
pandissix's Avatar
Let me guess. The old spice is for breaking a sweat.
Old 09-25-2012, 08:54 PM
  #874
David010567
ORIGINAL: pandissix
Old Spice is for...
armpit (ˈɑːmˌpɪt)
— n
1. Technical name: axilla the small depression beneath the arm where it joins the shoulderRelated: axillary
2. slang an extremely unpleasant place: the armpit of the Mediterranean
Old 10-01-2012, 06:25 PM
  #875
David010567
Progress... All (4) edges of the battery hatch are glassed. Top was glassed with (2) layers 3/4 oz cloth.
ID:	1807039   Click image for larger version
