Looking for an engine Reduction gear
Hello, Does anyone remember when reduction gear were available for big airplanes years ago?? Well, I am looking for a reduction gear for one of my engines, or at least plans to make one.. Any lead will be appreciated. allmetalplane |
RE: Looking for an engine Reduction gear
http://www.mickreevesmodels.co.uk/
Scroll down and click on "Other Kits", then scroll about half-way down that page. You're looking for "Torquemaster". |
You might check out this thread also.
http://www.rcuniverse.com/forum/WARB...2729670/tm.htm |
1 Attachment(s)
Maybe you can make something like this for your application. A few aluminim I beams and supports. OS 108 to turn a 19" variable pitch scale BF 109G carbon blades. Still working on starting system for engine.
steve |
DEar fellows,
Thanks so much for your great input, If I can get plans to a proven design, I think I can manufacture one at he hangar's machine shop. The reason I alm looking for the reduction drive is because I am building a rather large airplane and I want to stay away from gas engines due to possible potential ignition interference problems with aluminum airframes. The engine I am using is a MOKI. Again, Thanks for your input. allmetalplane |
| All times are GMT -8. The time now is 03:49 AM. |
