RC Conversion of the S-100 of ROG
1 Post
pictures of the first times out with my newly built S-100 ship from Revell of German..
Also seen are the insides of the boat w/latout for those who want to know how I did it.
this boat get get up and move for it's size...
Mark
Mark
RE: RC Conversion of the S-100 of ROG
Hi
The reason I asked about the motor is that I don't know what mine is either,I got it from a guy at work He think's it's from a printer bit is'nt sure.
People give me motor's all the time,I once came back from lunch to find half the insides of a vending machine beside my work bench,Got 8 motor's,gears, pulley's and a belt drive from that.
Anyway once again nice boat.
Hi
I used a Graupner 20mm prop on my boat,the 1/16" prop shaft is a tight fit in the thread's of the prop (2 mm) it's stuck on with green Loc-tite the bearing and sleeve retainer stuff been there for almost two years with no problem's
Bob
Bob
1 Post
ORIGINAL: bobslr
Hi
Bob
Hi
Bob
Does your boat have the torque problem starting upto top speed?
Please let me know
Mark
Hi
I can see the torque problem from your picture's,If you are using the kit prop's It's probably from the severe pitch on the blade's.
Here's some picture's of the prop I was telling you about, the one on the boat I had to blow up about 300% so you can see it, so it's not that good
Bob
Bob
1 Post
ORIGINAL: bobslr
Hi
Bob
Hi
Bob
my prop came off an old Battleship kit that was the right size.
Mark
Hi Mark
The prop's just over 3/4 of an inch in diameter and come in left and right hand so unless what your using is really small they should fit.
I'm using just the one motor and prop on 4.8 volts and the boat run along at scale speed,When I built the boat I put it in a wall paper tray to check for leak's and adjust the ballast well that went well so I turned it on and ran the motor, at full throttle it tried to climb out of the wall paper tray and sprayed water all over the kitchen. I was impressed and my wife was realllly impressed!
Bob
Bob
