Go Back  RCU Forums > RC Boats > RC Scale Boating
 Conversion of Tamiya/mpc PTs? >
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Old 04-18-2006 | 01:08 PM
MajorTomski's Avatar
Default Conversion of Tamiya/mpc PTs?
Hello all.
Finally got my dream home with a lake in the back yard, even better it's a secluded city owned lake, so they take care of it and I don't have to worry about someone drowning on my property.
Any whoo, did a search for PT, vosper, and Tamiya, and didn't get any hits on the success of converting the old Tamiya Japanese PT-15 or Vosper PERKASA. I realize they'd be extreme fair weather running only. I'm mostly curious if the stock running gear can push them along reasonably?
TIA
Tom
Old 04-28-2006 | 08:36 AM
Default RE: Conversion of Tamiya/mpc PTs?
bump
Old 05-05-2006 | 01:29 AM
Harquebus's Avatar
I didn't realize they were available as R/C, hence your usage of the term stock running gear.
In any event, I've seen them both converted to R/C using BEC to keep the weight low, micro servos and similarly small but high-torque running motors. If you position the weight slightly aft which allows the bow to ride over waves instead of plowing through them, they can handle amazingly choppy water. I'd recommend the PT-15 as it is bigger, wider, and has a smaller superstructure compared to the Vosper.
They plane out very well at speed.
-Harq
Old 05-06-2006 | 06:31 PM
Umi_Ryuzuki's Avatar
Here is a link to three pages on a Tamiya Pt-15
http://www11.ocn.ne.jp/~totsu/PT-15-1.htm
Even with the bow buried this deep in the wave, the author has no fears of sinking.
Old 05-17-2006 | 12:44 PM
Thanks guys
That last picture makes one want to consider renumbering from PT-15 to I-15
Old 10-26-2006 | 09:18 AM
Hi guys,
I'm from Germany and found this thread by using Google. This summer I made a conversion of the old Tamiya "Perkasa" that I built in the early 90's as a static model for the showcase. That means I made the conversion when the model was already completed. The model is powerded by a SPEED 400 6V from Graupner in combination with 6-7 AAA-size cells with a capacity of 800mAh. Click the following link to see the result:
https://fotoalbum.web.de/gast/der_sc...llboot_Perkasa
Greetings from Germany,
der_schwede
