SCREWS FOR GRAUPNER 700
This should be an easy one, but I can't figur it out, whear can I get the screws for the Graupner 700 motor mounts that mount to the front of the motor, thanks, Randy.
RE: SCREWS FOR GRAUPNER 700
Randy, the motor mount screws are metric, not sure what size. Hobby stores should have them,or try the hardware section at Home Depot or Lowe's. Roger
Thank you RW3D. I went to Home depot and 4mm fit the motor but seemed loose. I did find a link on the net which said 4mm so Iam going with it thanks, Randy.
The 700 motor has M4 threaded mounting holes.
I checked, and the M4 bolts do fit a bit loose indeed.
Never had one coming loose during running, if you use some nailpolish to secure them.
Regards, Jan.
Regards, Jan.
somewhere in your home town, there is probably a place that sells fastners and the like to the trade, a set of M4x10 allen key screws will be what you need, and as you only want a few, two for the motor and a couple for spares, you may have to pay just the gasoline it takes to get you there.
I picked up around 18 m4x50 pins for a diarama I was building along with enough nuts and washers for the project and it cost me a mere £1 for the entire bag full, so for 6 M4x10 pins, it will cost you cents, if that.
