Go Back  RCU Forums > RC Boats > RC Scale Boating
Reload this Page >
scale barge
RC Scale Boating Enjoy rc scale boating? Talk about it here.
scale barge
Old 11-05-2007, 02:19 PM
merc1500
Default scale barge
i have i 26 dumas shelly foss and i want to build a scale barge for any ideas on size many even have a pre made one out here on the web
thanks nicole
Old 11-05-2007, 08:17 PM
bigford
bigford's Avatar
Default RE: scale barge
dumas sells or sold a 2 barge set for $50.00ish
Old 11-05-2007, 11:50 PM
merc1500
is there anything already built not to good with wood
thanks nicole
Old 11-06-2007, 01:47 AM
herrmill
herrmill's Avatar
Why not consider making one out of foam, either block or built up using pink or blue insulaton board? Its easy to sculpt & conture into the shape you want & will certainly never sink! Just be sure you know what foam you are using before you try to fiberglass it - Styrofoam or polystyrene foam doesn't take well to polyester resin but can be used by first applying a barrier coating. Here's a good link for tips on using the medium.
[link=http://www.sculpture.net/community/archive/index.php/t-2182.html]Hotwire Foam Tips[/link]
I'm playing with it now between kits to make a simple Chinese river barge for the pond.
Chuck
Old 11-06-2007, 03:05 AM
Umi_Ryuzuki
Umi_Ryuzuki's Avatar
You could build it out of Aluminium...
I'm not joking... No, really... aluminium
Old 11-06-2007, 03:23 AM
herrmill
herrmill's Avatar
Umi, your barge is amazing! Did you every beat it up like we recommended over at the other forum & paint it in red lead & rust?
I'll post a few pics later this week of my block of foam - its become weekend therapy for me in between screaming at the contractors as they finish construction on the house.
Chuck
Old 11-06-2007, 04:31 PM
Umi_Ryuzuki
Here it is undergoing sea trials.
And one at the reggatta after we cracked the valve and sunk it.
All the tugs running around are chasing the cargo.
The system needs work, as it sunk perfectly, but had trouble pumping the ballast tank to refloat.
ID:	798356   Click image for larger version
ID:	798357   Click image for larger version
ID:	798358   Click image for larger version
Old 11-06-2007, 04:35 PM
merc1500
did you weld it
Old 11-06-2007, 08:29 PM
Umi_Ryuzuki
ORIGINAL: merc1500
did you weld it
No!!, I didn't weld it....[&:]
I had a friend weld it...
Old 11-06-2007, 10:01 PM
herrmill
herrmill's Avatar
Umi,
Loved seeing your barge as well as all those cargo containers floating around! I had no idea you planned to build your barge one that sinks for the tugs to chase around.
Would be interested in how you did your ballast system - I'd assume you are using a simple tank & reversible pump setup.
Chuck
Old 11-08-2007, 01:47 PM
Umi_Ryuzuki
It's just a submersible pump in the flood chamber....
It didn't refloat the first time, during full testing, because there was too much water coming in the gap at the deck and in spaces throughout the barge.
The second time, at the event, it wasn't properly balanced, and rolled over.
But there were lots of tugs to recover it.
Old 11-11-2007, 09:47 AM
BrooksSteam
These fun barges are not scale, but they are certainly easy to make:
http://www.rcgroups.com/forums/showthread.php?t=714083
A trip to an office supply store, or Walmarts, will yield many different sizes of bins that can be converted to barges.
