RC Submarines RC submarine discussions.
wiring
Old 08-29-2007 | 09:21 PM
Default wiring
wut do you hook the servos up to the battery or wut?
wut dos the esc do? does it make it so th remote control can control the engine if so how do you have to connect it to the motor?
if you plz answer any if not all of my question plz thanks
Old 08-30-2007 | 12:28 PM
Default RE: wiring
u ook the servos to da receiver
Da ESC make the motor go fast and slo. It plugs into da receiver on one end. The other end connect the
ESC to da motor. U connect it with wires. Guess wut, the ESC has the 3rd end too! It connect to da battery.
A receiver is like FM radio it recieves radio signals. Soory no music, just da signals from ya transmittar.
U need 3 channels for a dynamic deever and at least 4 ch for a static boot.
By theese http://www2.towerhobbies.com/cgi-bin...I=LXCJG8**&P=0 and be appy
Old 08-30-2007 | 04:40 PM
Default RE: wiring
thanks alot but do you hav to buy any wires or anything where do you buy pushh rods cuz i don't think they have them here? do all batterys have the same plug or do the battery have all different plugs? ohh one more thing if you have two motors do you have to have to esc or recivers? thanks
Old 08-30-2007 | 06:29 PM
Captain Nemo12's Avatar
Default RE: wiring
if u by ur radio system as a set no u dont need any wires unless u plan on bying thingz like servo extensions those are xtra wires u use to lengthen teh distance if u hav a long sub hull batterys generaly come with appropriate plugs most use tamiyas style connectors that fit wit most escs and if u hav too moters you can use two escs or use only one if the current is not too strong ur sub only has one reciver hope this helps
Old 08-30-2007 | 09:45 PM
Default RE: wiring
just wondering wut would be the best motor to get if u only wanted one for ur sub? and if it possible im on a low buget
Old 08-31-2007 | 04:48 PM
Default RE: wiring
Try a 540 size Mabuchi or Johnson, they are usually cheap (can be found at electronic surplus stores), although I heard that they can be quite power hungry.
Old 09-11-2007 | 09:01 PM
Default RE: wiring
wut about two motors for a boat wut is a good moteor for a twin motor sub? and do you have to buy a speail cord that split in two for twin motors? thanks
MAtt[8D]
Old 09-12-2007 | 02:56 AM
Default RE: wiring
Get two 540 size motors, and get 2 lots of wire.
Really, I think that maybe you should start out with an RC kit car/ buggy or something, so you can work out the basics.
Old 09-12-2007 | 09:07 PM
Default RE: wiring
dude i almost know everything about this and i might convert the U2540 type XXI so im just asking any last questions that i have but thanks for the suggestions
Matt[8D]
