airsoft modification
Old 09-14-2010 | 08:55 PM
Eggman1965's Avatar
Default airsoft modification
Is it possible to rewire the RX-18 Hl tanks to fire the airsoft cannon using the K switch instead of the left joystick? Also I was hoping to upgrade my airsoft BB shooters to get a little more power out of them, before the Oct 23rd tank meet in Ft Erie. I notice the airsoft motor has a small capacitor soldered across the terminals, is this to stop the inadvertent reversing of the motor?
Old 09-14-2010 | 09:33 PM
Default RE: airsoft modification
<font color="#00265e" size="2">thomasjohnmurphy</font> is an Expert on Airsoft modification.</p>
Old 09-14-2010 | 09:35 PM
Perry S.'s Avatar
No, the cap across the motor is to reduce electrical noise. Diodes affect the direction of current travel, not capacitors.
Perry
Old 09-15-2010 | 06:48 AM
Eggman1965's Avatar
ORIGINAL: Perry S.
Perry
You know as soon as Iposted I realized my gaff! So any small capacitor of comparabe rating should do the same job I'm assuming.
Old 09-15-2010 | 07:45 AM
shenlonco's Avatar
Yes the cap should work.. On the K button i don't think the airsoft gun will work off it as the action of the K button is a fast bleep of electric then it stops where as pushing up on the stick is consistant electric so it can fully turn the guns motor at any time to shoot. with the K button it would give a little pulse and move the motor in the gun only a hair making it not shoot.
Old 09-15-2010 | 07:54 AM
Fireman Tim's Avatar
Egg,
John explained to us (and TJM, correct me if I am wrong) that there are basically three things that need to be changed with the existing HL Airsoft system.
1) Improved Barrel and correct length.
2) Shortened return spring.
3) Acorn nut in the main spring chamber to allow for spring rotation during compression.
Get it right and you have a killer airsoft gun, get it wrong and it will blow up on you.
Now how to do all these thing, I have no clue, gonna have to wait till Oct 23rd. But John could refer you to the right barrel to purchase.
Old 09-16-2010 | 11:15 AM
Could you share your experience after the meet? I am looking to change my IR KV 1 to an airsoft gun from VS, any tips would be helpful!
Old 09-16-2010 | 12:14 PM
Here is what I have gathered from TJM's previous posts.
here's a trick. Shorten the small return spring (cut it in half then fold over the first rung to use to secure to the unit. That has happen to me where both plungers (outer and inner) release at the same time. With the added stress with the upgraded shooting spring for some reason causes the outer plunger not to release when it is suppose to. I remedied this with either shortening the small release spring thereby creating more force when the bb is set, or putting a stronger spring in (remember there are 2 springs - shooting spring which drive the plunger to propel the bb, and the smaller release spring to set the bb. Hope this works
its always best to have a clean inner barrel for any gun (even these airsoft guns) You can also replace the inner barrel to reduce the amount of blow-by. The Stock HL inner barrel has about a 6.15mm inner diameter. I've been using tight-bore barrels with about 6.03mm or 6.04mm inner diameter. Hugh difference in power
10cm is a good length for an inner barrel
because of the length of the inner barrel the air pressure caused by the airsoft unit can only accelerate the bb if the air pressure behind the bb is greater than the air in front of the bb. the holes allow the air to escape as the bb travels out the barrel. As well, the the bb passed the small hole it allows air to get sucked in. without the hole there would be a vaccum created causing drag on the bb. I've found that all you need is about a 10cm long inner barrel of optimal firing. I replace the stock inner barrel with a cut piece of a tight bore inner barrel. The stock inner barrel inner diameter is about 6.15mm. A tight bore barrel is about 6.03. This reduces blowby (air escaping past the bb when the airsoft unit is fired. A typical stock HL airsoft gun will shoot about 60-90fps. I've had my guns shoot as hight as 235fps
I picked it up on ebay. I'd get a madbull tightbore barrel (6.03m) 650mm length and cut it using a plumbers cutting tool. The barrel is aluminum so its easy to cut. You will have to drill out the breech to 11/32 of an inch (don't go too deep as it could crack it and the you may have problems) As well, you can put spacers in the plunger to preload the spring)
[link]http://www.rcuniverse.com/forum/m_8897740/anchors_8897740/mpage_1/key_/anchor/tm.htm#8897740[/link]
[link]http://www.rcuniverse.com/forum/m_8353653/anchors_8355733/mpage_1/key_/anchor/tm.htm#8355733[/link]
I hope this helps.
Tim
Old 09-16-2010 | 12:16 PM
More TJM wisdom:
first piece of advice
get several replacement units (with the yellow cap motors) There are ones with blue cap motors that are a bit different and won't upgrade- to the extent of the yellow cap motors
what you will need
a stronger (heavier guage)spring (mine are 1 3/4" long by 1/2")
a tight bore inner barrel (you will have to cut it to length and clean out the cut end so the bb will roll freely. As well, you should drill a hole (1-2mm) about 3-4 inches down the barrel. make sure the hole's edges are cleaned so the bb rolls freely.
a spacer (about 1/4 " hex nut) I use 2 to preload the spring, Its about 1/2' total spacing. I even add a few washers to refine the power. These go inside the plunger.
a # 2 washer to compress the tall gear
two #1 washers to compress the second gear from the plunger
you need to cut the small plunger spring in half to increase the power the return plunger sets the bb
you will have to bore out the plastic breach to fit the new inner barrel. Be careful or you may crack it. Don't drill to far because the barrel will hae to set against the rubber seal properly. Even being out byt a fraction of a mm and you gun won't fire regarldess of what you do. You will have to drill it our to 11/32" I start with a smaller drill bit and work my way to that one. I even heat the breach up so its more flexible
I secure the barrel to the gun with a small screw (I drill a hole int he top of the unit and just slightly into the barrel inside the unit. Then I use a small screw to secure it once the barrel is set properly in the unit. (I usually fire several dozen bbs to test the gun and tweat it unti I am satisfied
Old 09-16-2010 | 12:36 PM
Thank you Tim, bookmarked for future reference. I hope to be able to do it one day, my skills at the moment are rather limited.
