modification of the lifting mechanism gun barrel Heng Long tanks.
Hello again.
Now I present to you the modification of the lifting mechanism gun barrel Heng Long tanks.
Remote control does not change
All changes in the motor control circuit inside the tank.
[youtube]http://www.youtube.com/watch?v=vvzTWbaZXiM[/youtube]
RE: modification of the lifting mechanism gun barrel Heng Long tanks.
I have not changed any RX-18 or the lifting mechanism gun barrel. I did not change control of the transmitter sticks. But I made it possible to control the angle gun barrel is not cyclic. The only difficulty - is the passage of the extreme positions of the barrel. Not yet put the stopper rotation gearbox - so long as I can manage both the cycle and not on a cycle.
one relay with two pairs of contacts on the circuit-breaking
I switch it relays a signal rise gun barrel
commutating voltage motors turret
the left stick left-right - the relay is normally closed, the wires to rotate the tower through the relay goes to the motor turret
the left stick down - the relay throws these wires to the motor hoisting gun barrel
the left stick is not picking up a left-right - in a closed relay contact voltage turret - the motor lifting gun barrel
In parallel coil relay - a diode in reverse polarity to the supply voltage
