Lithium battery pack for Tamiya King Tiger?
GA
Hi ya'll, I'm new and have ordered the tank but have not found just which batteries to get
Are any Lithium packs to fit and who gots it.
Thanks, for any help.
RE: Lithium battery pack for Tamiya King Tiger?
Are you speaking of Lipo batteries?
You will need a lipo balance charger first for lipo packs and a Low voltage lipo alarm because the tanks do not have a lipo low voltage cut off in them and if used in a tank without it the battery can get damaged and result in a fire when charging it again.
GA
Thanks Shenlonco, Didnt know bout that. What i have found said it required 7.2v NiCad batts.
I would like to start out right with quality batteries and charger. Any info on what to get
and where to get will appreciated.
ORIGINAL: jmose
Hi sounds like you are not to good with chargers and batteries so i say for you go simple and easy...
Get a onyx 200 charger first on this page $23.00 it will be good for you and simple to use
GO HERE: http://www3.towerhobbies.com/cgi-bin/WTS1000p?&C=P
and get one of these and you will be good to go!
http://www3.towerhobbies.com/cgi-bin...?&I=LXAAGE&P=7
KISS, Keep It Simple Stupid. Not saying you are stupid, in the contrary. just asking the right questions makes you a smart guy but listen too Shenlonco. He is pretty much our resident charger/ BatteryPack Guru. he wont steer you wrong. he is also our clubs main tech guy, so i know him personnally. Good man.
GA
Thanks Shenlonco, just what we needed. I built airplanes and was the pit crew for my son years ago.
Got airplanes and 4-strokes hanging all round the garage/game room/shop.
lost him to computers and to college 2 yrs early. Seldom see him. Now he is gonna be home
2 whole weeks and wants to build a Tank... Hot Dog!!!
Thanks a bunch,
jmose
Thanks Panther G those are some nice kind words and I appreciate it.
I like to help any way I could and from reading Jmose post he did not sound sure about what he was trying to do so I figure set him up with a simple select amps on a switch push the button and let the charger do all the guess work for you kind of package deal.
Have FUN wrenching on the tanks!!
Is there any low-voltage cutoff device that can be purchased as is an plugged between the battery and the Tx board?
ORIGINAL: Gerula
I'd like to, but obviously I'd need a LVC device that will cut off before the Li-Po gets destroyed (the HL Rx goes in flat battery mode at 6v which is too low for a 2s Li-po)
Hence the question. I was hoping that such device can be purchased.
Hi these are the best you can get I tried lots of them this one is so loud you can hear it from far away very easy!!
It has 2 alarm buzzers 95DB!! Get a lipo with the JST type balence tap you stick the LVC into the plug it beeps and it's ready to go.
I just put it in the battery compart ment I never realy hit LVC anyhow with it and it's good because it's a little higher 3.3V cell.... What you can do also is there are red lights that come on much before the buzzer as a warning batt is getting low you can unsolder the 2 leds that are used for the 2S battery and run them up on or in the tanks exhaust pipeds so you can also see the leds before buzzer and shut down the tank.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
IN
ORIGINAL: shenlonco
ORIGINAL: Oracus
Thats a very good idea, I might have to use that one
ORIGINAL: shenlonco
GA
Shenlonco ,that gizmo looks like it would be good to have with any battery pack. Will it work with
or be modified to work with NiMH batt packs?
jmose
jmose
ORIGINAL: jmose
jmose
jmose
With NIMH just make sure you never let them sit for a long time when not using them every few weeks put them on the charger and put some power back in them because they self discharge when not in use and if they get to low of voltage they get ruined.
I believe it is settled fact that you can safely discharge a Lipo cell to 3.0 volts(no-load only, and only done as part of a discharge/charge cycle on a modern charger). Battery damage only occurs after you go lower than 3v per cell. Under a load situation, such as driving one's tank, you should be able to safely the tank to a 3v cut off without battery damage as the battery voltage sags the most under the load. Not recommended (why tempt fate??) because less than 3.0 v will kill your lipo (which can easily cost more than a HL tank), but probably safe nonetheless.
ORIGINAL: Jeff489
ORIGINAL: shenlonco
Thanks for the link, 95db sounds like enough. Also moving the leds outside the tank (maybe positioned as convoy lights) is definitelly a good idea.
Definitelly a 5 stars post.
