Upper Body Hinge
ON, CANADA
Upper Body Hinge
I want to hinge the top half of my Dad's HL Pershing so that he can lift the top off and access the inside without unscrewing everything.
Has anyone done this and/or have pis of their work?
RE: Upper Body Hinge
I did a similar thing with my M-41B. Just hooked the front under the lower bow plate and lift the rear up, like the hood of a car. ...just make sure the wires are long enough. Doesn't need any screws as the hooks on the front stabilize it. .
ON, CANADA
I was thinking of using rare earth magnets and metal brackets.
May be a bit different on the Pershing, But for the '41 I just tapped a small hole in the sides above the idlers and put in a small screws...get it far enough up front that the upper hull clears and hinges over the lower hull. At first, I had it too far back and it only allowed me to lift about 3 inches..Could easily put a small piano hinge at the bow,, but then there's a chance of a small opening. I haven't had my Pershing or M-45 opened for months, but thats the deal on the M-41B..
The issue with the Pershing is you need to move the upper hull up and forward from the rear lamps to take the top hull off. Cant just do it with hinges. Velcro or magnets. Remember the screws also help add stiffness to the whole tank. I only use a couple in my tanks now or one in each corner.
