Looking for some advice on project
MI
Hey guys....
I've never owned an RC tank, but have had a slew of off road cars and a helicopter.
I do structured cabling work, and am trying to come up with a radio controlled vehicle to help me pull data cable.... mostly Cat5.
I've tried an Emaxx, which was able to pull 6 1000' spools across the floor but was too large for ceilings as well as a mini-t to pull a fish line, but neither was able to really get over some of the obsticals I've come across. In general I'll be stringing a single data line per pull.
I think a tracked vehicle would be best suited, but I'm having a hard time finding anything used to give the idea a shot and buying new is a bit too pricey for the gamble on this even working out. I looked at a few that were more toy grade, but I'm doubtful on them... add to that if this works I'm going to have to go DSM on the radio due to interference in the locations I'm servicing.
I know this is a bit of an off the wall post, but if anyone can point me in a direction or offer some advice I'd really appreciate it!
RE: Looking for some advice on project
If you can do it, I think a custom build may be your best bet and will most likely be cheaper and give you the most bang for your buck.
What Sort of specs are you looking for ?
Weight
Size
Speed
Max weight to be pulled
I built battlebots back in the day so ROV's are my cup of tea.
If you like I have a machine shop and small aluminum foundry so I may help with a build.
A good parts source for parts of this type iswww.robotmarketplace.com/store.html
FF
Weight
Size
Speed
FF
RI
Actualy if that is all you need it for just build up the hull and running gear, that would also keep the profile low for above ceiling work. Buy a Tamiya and use the plastic tracks that come with it to prevent any chance of shorting any exiting wiring. Grab a Gear Down from ETO Armor and it should work fine for what you want to do?
Here are some robots that may work for you.
www.robotshop.ca/summerour-traxster-robot-kit-1.html
www.robotshop.ca/dagu-wild-thumper-6wd-all-terrain-chassis-aluminum-75-1-2.html
FF
FF
The tank you seem to be looking for is the Heng Long Stug III. It is inexpensive, has a low center of gragity, has low overall height and is light and strong. Keep the tank light weight so it will climb easily and not mash down insulation too much. The lights on the front should help you guide it thru dark spots.
Good luck, Bob
Good luck, Bob
Use an M-41 hull without the turret, which would give you a lower silhouette and the M-41 has more ground clearance than most others. The Pz III is small and as with the M-41 suggestion, remove the turret....you could install a mini cam on the lower turret section to give you "eyes on target".
I think the last 2 suggestions from PC and the commander would work the best, and like sevo said add some "ballast " to give more traction. the camera is also a very good idea. The PzIII hull and suspention are very good. The Pershing is a little wider I think but is also a very good suspension. And yes , plastic tracks are a must for safety reasons. Go for , short , narrow and ground clearance, probably in that order.
