M41
Old 06-26-2011 | 11:22 AM
Default M41
Hi Guys,
I've been meaning to post these Bulldog photos for a while. I remember there were some questions about the suspension configuration a while back. These pic's are a little confusing since the turret's reversed. Also, are the tracks installed backwards on this machine?
ID:	1627904   Click image for larger version
ID:	1627905   Click image for larger version
ID:	1627906   Click image for larger version
ID:	1627907   Click image for larger version
Old 06-26-2011 | 11:38 AM
Airbrushler's Avatar
Default RE: M41
looks like their vinyl stickers are coming off to they should paint the stars on and the division symbol they never had stickers
you can see it in the second pic edges are turned up
Old 06-26-2011 | 11:53 AM
Panther F's Avatar
Default RE: M41
Tracks are correct.
- Jeff
Old 06-26-2011 | 12:25 PM
pattoncommander's Avatar
Default RE: M41
Doesn't look that bad. It always amazes me why some idiots want to display tanks with the gun to the rear....Ours had the gun welded into the travel lock and it took our shop a week to get it loose and some of the weld scars ground off.
As Panther F wrote, the tracks are OK. Very unusual is the sledge mounted on the turret. Most of the pioneer tools are left off as they get stolen any way.
Old 06-26-2011 | 03:31 PM
Default RE: M41
Gregg, many museums are using vinyl as the markings are easier to apply, look neater and last longer. Making and applying stencils on tanks is not the easiest job. The armor patch is not kosher but at least they have the Geneva Convention stars of the correct size and in the proper places.
Old 06-26-2011 | 06:18 PM
Default RE: M41
Thank you Jeff. Hi Pattoncommander, I'm friends with one of the senior guys at the veteran’s center. They brought in a heavy crane to move the Bulldog to its present location from across the road where they have now built up an elaborate memorial site. The first order of business prior to the whole tank swing was to lift and re-orient the turret. He said they tried everything, including cutting open a hatch and sending a welder inside. Every time they tried to lift the turret the whole vehicle would rise. Apparently the Kaydon bearing has been removed and the turret is welded to the hull. It was a horrible mess, worse than it sounds, and they ran out of time and money. Included are additional suspension shots.
ID:	1628136   Click image for larger version
ID:	1628137   Click image for larger version
ID:	1628138   Click image for larger version
ID:	1628139   Click image for larger version
ID:	1628140   Click image for larger version
ID:	1628141   Click image for larger version
Old 06-26-2011 | 10:37 PM
Default RE: M41
Hi vollenc,
    Thank you very much.
Samattapol</p>
Old 06-27-2011 | 04:12 PM
Default RE: M41
man, what a shame....ridiculous what people do to artifacts when they don't know what they are doing.
