 Which controller for Leopard 2A6 >
Old 07-28-2011 | 03:47 AM
Default Which controller for Leopard 2A6
I just purchased a 1/16 Tamiya Leopard 2A6 from ebay. The set comes without controller. Which brand and type od controller should I buy for this tank? Nothing fancy, just the basic tank functions.
Old 07-28-2011 | 04:45 AM
Default RE: Which controller for Leopard 2A6
Spektrum dx5 is a decent controller , got mine off ebay for £52 with rx as well. Decent brand, good features people seem to agree theyre reliable.
Old 07-28-2011 | 04:46 AM
The Leopard has a few more functions than a standard Tamiya or HL tank so i would get something with at least 6 channels, maybe 8. The Futaba radios have some very nicely priced 2.4 computor radios available now and Airtronics has a great 8 channel. the draw back to the airtronics is you must use the 8 channel receiver made for that radio and it costs anywhere from 60 to over 80..00 dollars depending on where you buy it.<div> The Futaba receivers are much less and you can use many more combinations of TX/RX with them. It basically is up to user preference.</div><div>Do some research and checking on your own and decide what is best for you. No one can really tell you what YOU want from a TX/RX so the user really needs to do some home work.</div><div> You can use a simple 4 channel radio like the Futaba SkySport 2.4. It is a nice radio but most people my self included add 2 momentary switches to activate the main gun and machine gun, instead of moving the trims and flipping the levers to fire the guns. </div><div>that is how all Tamiya tanks are set up to fire the guns. Not much fun when you are in a really tough spot in a battle.</div>
Old 07-28-2011 | 05:20 AM
karel47's Avatar
i would go for this one if you can get it : http://cgi.benl.ebay.be/ws/eBayISAPI...=STRK:MEWAX:IT
Old 07-28-2011 | 05:21 AM
karel47's Avatar
am using graupner for more then 22years for now, it's a very quality merk, you can get it everywere
http://cgi.benl.ebay.be/ws/eBayISAPI...m=380357618133this the link with the new action on ebay it cos normaly 300&euro; here in belgium
<font color="#002398">Graupner 8-Kanal Fernsteuer​ung MX-16 IFS 2,4 GHZ 23000</font>its now 188&euro;
Old 07-28-2011 | 05:28 AM
karel47's Avatar
on the graupner site costed this receiver set 342&euro; go look
https://shop.graupner.de/webuerp/servlet/AI?ARTN=23000
<div id="aicol1"><table cellpadding="0" width="100%"> <tbody> <tr> <td></td> <td width="400"></td> <td></td> <td width="400"></td> <td></td> <td width="400"></td> <td></td> </tr> </tbody></table><div class="lt"><p class="headln">Beschreibung</p><p class="textblock">Durch Spitzentechnologie optimiertes Computer-Fernsteuersystem mit 12 Modellspeichern. Hohe Funktionssicherheit durch modernes Computersystem und Einsatz der Graupner 2,4 GHz iFS-Technologie. Bidirektionale Kommunikation zwischen Sender und Empf&auml;nger. Problemlose Programmierung durch vereinfachte Programmiertechnik. Ein kontrastreiches Grafik-Display erm&ouml;glicht eine pr&auml;zise Anzeige von Batteriespannung, Modulationsart, Modelltyp, Modellnamen, Modellspeicher-Nummer, Einstelldaten, Drossel- und Pitch-Kurven sowie Modellbetriebszeit.
Servo-Aufl&ouml;sung: 65.536 Schritte (16 bit).</p><ul> <li class="square">Microcomputer-Fernlenksystem in modernster 2,4 GHz Graupner iFS Technology <li class="square">Bidirektionale Kommunikation zwischen Sender und Empf&auml;nger <li class="square">Quarz und Kanaleinstellungen enfallen. Gleichzeitiger Betrieb von bis zu 120 Sendern st&ouml;rungsfrei m&ouml;glich <li class="square">Schnellste &Uuml;bertragungsrate f&uuml;r extreme Reaktionen <li class="square">St&ouml;rungen durch Elektromotoren, Servos und elektrischen Aufladungen (Metal noise) nicht mehr m&ouml;glich <li class="square">Kurze Antenne umklapp- und abnehmbar <li class="square">Bedienung und Programmierung angelehnt and die bew&auml;hrten Konzepte von mc-19 bis mc-24 <li class="square">Ein kontrastreiches Grafikdisplay gew&auml;hrleistet perfekte Kontrolle der Einstellparameter, Betriebszust&auml;nde, Uhren und der Betriebsspannung. <li class="square">8 Steuerfunktionen mit vereinfachter Zuordnung von Bedienelementen f&uuml;r Zusatzfunktionen <li class="square">Freie Zuordnung aller Schalter zu Schalt-Funktionen durch einfaches Umlegen des gew&uuml;nschten Schalters. <li class="square">12 Modellspeicher, modernstes Backup-System ohne Lithium-Batterie <li class="square">4 Schalter (davon (ein 3-Stufen-Schalter), 1 Taster, 1 Analogsteller, 2 Digitalsteller bereits eingebaut und vielf&auml;ltig frei programmierbar einsetzbar <li class="square">Funktions-Encoder mit Drehwalze und 3 Momenttasten erm&ouml;glichen vereinfachte Programmierung und pr&auml;zise Einstellung <li class="square">Einfache Umschaltung des Betriebs-Mode 1 ' 4 <li class="square">Graphische Servo-Anzeige f&uuml;r einen schnellen, einfachen &Uuml;berblickund &Uuml;berpr&uuml;fen der Servowege <li class="square">Umfangreiche Fl&auml;chen- und Helimen&uuml;s <li class="square">Servo-Wegverstellung f&uuml;r alle Servokan&auml;le und f&uuml;r jeden Endausschlag getrennt einstellbar <li class="square">Sub-Trimm zur Einstellung der Neutralstellung aller Servos <li class="square">2stufiges Expo-/Dual-Rate-System, einzeln einstellbar, w&auml;hrend des Fluges umschaltbar <li class="square">Mixerfunktionen Programmierbare Fail-Safe-Funktion &raquo;Halten&laquo; oder &raquo;voreingestellte Positionen anfahren&laquo; f&uuml;r jeden einzelnen Servokanal getrennt einstellbar <li class="square">Stoppuhren/Countdown-Timer mit Alarm-Funktion <li class="square">Modell-Kopierfunktion f&uuml;r Modellspeicher[/list]
Das Set enth&auml;lt
Microcomputer-IFS-Sender mx-16 IFS mit eingebautem NiMH-Senderakku, Empf&auml;nger XR-16F IFS, Servo DS 8077, Schalterkabel
</p></div></div><form id="aicol2" method="post" action="AI"> <input type="hidden" name="Servletname" value="AI" /> <input type="hidden" name="NoSessionCheck" value="1" /> <input type="hidden" name="NoStack" value="1" /> <input type="hidden" name="ARTN" value="23000" /> <div class="bez">MX-16 iFS COMPUTERSYSTEM 2,4 GHz kompl.
Best.-Nr. 23000 <span class="preis">EUR 342,50 <sup>*</sup> </span>
<span class="preis2"><sup>*</sup> unverbind. Preisempfehlung inkl. MwSt.</span></div> <div class="aktionen"> <div class="input"><input maxlength="11" size="11" style="text-align: right; margin-bottom: 10px" name="MNG-" type="text" /> <input title="In den Warenkorb legen" alt="In den Warenkorb legen" src="/webuerp-custom/images/btg-inWK_de.gif" type="image" name="inWK" /></div> <div class="error"></div> <div class="info"></div> <div></div> Zur Merkliste hinzuf&uuml;gen
<div class="info"></div> Zubeh&ouml;r
Druckansicht
Weiterempfehlen
<div class="info"></div> <span class="hinweis">Dieser Artikel ist lieferbar</span>
</div> <ul class="urls"> <li class="url first"> Anleitung <li class="url "> iFS xdp setup V3.1 <li class="url "> iFS updater 24 <li class="url last"> Lehrer/Sch&uuml;ler RC-Anlagen-Verbindungen[/list]<div class="zt first"> <p class="headln">Technische Daten</p> <p class="textblock">Steuerfunktion: 8
Temperaturbereich: '15...+55 &deg;C
Antennenl&auml;nge: 108 mm
Gewicht ca.: 820 g
Frequenz: 2400 MHz
Abmessungen ca.: 195x190x85 mm
Modulation: 2.4GHz
Stromaufnahme: 190 mA
Betriebsspannung: 9,6...12 V
Betriebsspannung: SMA-Anschluss V
</p> </div></form>
Old 07-29-2011 | 07:47 PM
If your only intended use for this radio is surface models then you can consider a cheap n cheerful Hobbyking 7 channel.
http://www.hobbyking.com/hobbyking/s...&v=&sortlist=P
7 channels for $60 + post
Old 07-30-2011 | 04:48 AM
Buckeye36's Avatar
The RDS8000 can use any Airtronics 2.4GHz FHSS-1 Receiver.
That includes the RX500, RX60, RX600, RX700 and the92824 8-Channel receiver includue with the radio.
There are less expensive receiver options for the RDS8000.
Old 07-30-2011 | 05:40 AM
Pah co chu puk's Avatar
I got the Futaba 4YF  2.4GHz<div>
</div><div>It is a 4 channel.  It seems to work well in bench tests, my Leo is not complete yet, but the way to shoot the gun does seem "lame".  </div><div>
</div><div>How do you guys with 6 channel setups separate out the gun fire function to make that work?  It sounds better than the 4 channel way.</div>
