Missing screw?
I just got a new strumgeshutt III, and the left side sprocket wheel came off. I looked all over and I couldn't find a screw that might of come out. I noticed. The inside wheel had bumps on it, and the outside had matching holes. I attached the wheel to the track, banged the wheel together with the inside one and it seems okay. If there is a screw, does anybody know the size, and where I can get it. It's a hen long upgraded strum.
thanks and merry Xmas.<br type="_moz" />
Is it heng long, You can get them from a hardware store, if it's the one that holds the sprocket on it's size m3 about 12mm long, take the one out of the other side and that will give you the length
regards Jack.
regards Jack.
If you can't get one at your hardware store send me a pm. I certainly would have one or two laying around.
ORIGINAL: Lamp02
