VSTANK 2.4 GHz review
And you can run up to 16 2.4 GHz vstanks at same time. Note using VSTanks crystals you can get up to about 13 tanks running now i think on old radio system. Thats it folks not one other new thing on this example at least.
Still three speeds same sounds etc no volume adjustment on this one either
In my opinion if you are going to buy one just because of the"new 2.4 GHz " don't bother I like VSTanks and have all they make in WW2 and in multiples until i see something"new" or find it dirt cheap im done with giving them any more money.
first
Hard to believe they didn't include other up grades like porportional speed control and sound. Well this switches me to plan B, buy a clark board and give it a try. I think it would make these tanks awesome. Since VS seems to have stop putting out new tanks and I have all the WW2 tanks twice or more over I think I will spend my money on clark boards and then I will be able to combine my VS tanks with forces of valor tanks and they will all be able to battle each other.
I was really looking forward to the Jagdtiger and sdkfz 222, but I don't think we will see anything else from them as its been over a year and a half since the have really said anything on their website.
Thanks again for the report.
Greg
So earlier last year I was very interested in keeping with that scale & purchasing new VSTanks to hopefully start a dedicated 1/24 scale RC tank club in my area. But after some emailing to VSTank, & finally receiving one response last year, I was disappointed with their vision of what was in store for the 1/24 VSP IR line of their tanks, so I decided to abandon that scale altogether & move up to the 1/16 scale which has a lot more options.
Below is some of the email, as well as what I had asked & was told by someone in May 2012, signing off on the response email as "Steve" ( supposedly the founder of Toyeast & VSTank ), who replied to about my 3rd email I sent asking questions about the intended direction of VSTank, his responses are in red.
1.) The most important current issue for large tank clubs is that there are only a dozen or so 27MHz range frequencies available for the VSTanks, only allowing possibly 12 tanks to run at any one time. A devoted RC tank club needs more than 12 tanks to be able to run at any one time.
Will Toy East be adding either 75MHz controllers which would add about 30 more frequencies for tanks to run, or 2.4GHz spread spectrum frequency controllers which would allow even more tanks than 30-40? If you will be doing this, can you tell me when (month?, year?) it will be done?
2012 this year > Guarantee we will have 2.4G (controllered by TX) and Bluetooth (controlled by iPhone) will be released.
2.) Improving the accuracy of the IR transmitter/receiver. Many times with the 6 tanks I own, a target tank will register a hit even though the attacking tank was aiming in a direction pointing 1-2 feet away from it. This happens in open areas inside & outside when battling. Realistically of course, you only want a tank to register a hit when the attacking tank’s barrel is actually pointing directly at another tank.
Has the IR accuracy been changed & improved in the newest tanks in any way from those that I purchased 5 years ago?
If the IR has not been changed, would Toy East consider trying to make it better, maybe by using an IR led emitter that has a more narrow sending beam angle that could improve to hit accuracy?
There is always a angle by IR emitter, there is always a balance needed to by made. If too accurate, children will lost patient or even claim tanks is out of order and return. So, if professional play like you, you can push the emitter inside the barrel a bit, so the angle will be more narrow
3.) Add realism to battles by adding a selective hit counter instead of every tank taking 6 hits to disable them. Like adding a selective hit range for light, medium, & heavy tanks, that a tank owner can switch on their tank, where a “light tank” setting would take 2 or 3 hits, a “medium tank” setting of 5 hits, & a “heavy tank” setting of 10 hits. Or even better, use a dipswitch located inside the battery box of each tank which has 1,2,3,4 switches that would allow setting each tank from 1-10 hits by changing the little dipswitches positions.
Is Toy East considering adding a selective hit counter, so RC tankers can select the number of hits it takes to disable their tank during each battle?
This can be achieved at upcoming wifi tank by iPhone 5 at 2013, all App controller sound, speed, hit number, life.....all can be calculated by iPhone but not a fixed MCU inside the tank.
4.) Better sounds for better realism. Each tank should have different sounds depending on which tank type it is, rather than all tanks having the same exact sounds. Adding engine idling sounds to all tanks so even when they are not moving they still sound as though they are turned on & working is also wanted.
Has Toy East given each tank their own unique sounds, or at least improved the sound quality on all tank models?
Do all or any of the tanks now have engine idling sounds as soon as they are turned on to remind us they are still working even when sitting still?
Same answer as #3, for your info, we have full set of sound on nearly every tank for 3 years, except T72 and Type 90 (If you can help to locate, that will be great, we can reward one free King Tiger as gift if you can help to locate this two real tank sound source).
Actually, VsTank start from 2002, and the 1/24 VSP start up and develop in sonic speed at 2003-2009. We released almost 10 models at this period. I think every company, business development speed vary time to time. At that time, we have a huge Russian customer invest the tooling on the Russian Tank Tooling (Each Tank talking about $40000 USD), so we can release so many tanks.
However, the development slowed down while our Russian customer has financial difficulties. Actually the world economy problem suffered for almost 5 years, and I believe need at least 5-10 years to recover. As a boss of this company, we foresee the sales of tanks will be affected and we cannot survive if we don't change. So in past two years, we invest some resource on other electronics products - iPhone accessories. But
We keep on the exhibition and meet Apple, Apple invite us to make iOS tank, so we got MFi license (Made for iPhone), and start from JAN, the new Bluetooth VsTank will be released very soon.
At 2012 this year
1. We will have Apple iOS controlled VSP (called VSB, B for Bluetooth) 1st Generation, this tank control distance is 2.5 times over am 27MHz
2. We will have VSI, also Micro RC Tank controlled by iPhone
3. We will launch 2.4GHz VSP
At next 5 years, we have a quite pioneer roadmap, especially by using Cloud and Wifi technology by mobile device, weuse screen on mobile, to show the hit reaction and showed up the life-count, vibration, explosion visual effect on the Mobile. This innovative idea functional sample will launch this year and sell at next year. And Wifi technology will bring even higher excitement by putting camera to the tank and show the battle at the 1st angle via the Mobile Screen, also can connect with other friends. Our target is two wifi-camera VsTank in your home, your friend can stay at home, connected via cloud and battle with you.
I can say that all of these VsTank has very pioneer strength to develop because Apple invite us, we are the only RC Tank manufacturer that Apple gave the MFi license. And we have knowledge and experience on connecting battle tank and mobile.
I had also sent several more follow-up emails with some more questions later in May & in June, but neither "Steve" nor anyone else ever responded again, so I decided it was time to just move on ... Some people may love the direction VSTank is taking their line according to what I had been told, however, since I'm not really into the wifi enabled or phone controlled tanks at this time, their focused direction wasn't where I wanted to go.
The 2.4GHz control was something I had been looking for, but still only allowing about 16 more tanks you say kennywsp, seems like a waste. Since the regular radio controlled VSP line wasn't getting any better battling features added or upgraded like I had hoped, I also couldn't justify paying $80-$120+ for a 1/24 scale tank, then having to add another $70-$100 in Clark board & other upgrade parts just so they sound better & have much better IR battle functionality. I'd rather spend $300-$400 while buying & upgrading a new 1/16 scale tank that is a bit more "tank like", & has a lot more choices & upgrade options with it's much larger after-market parts selection.
The other blow to this scale of battling RC tanks, is that Unimax has apparently decided to abandon the 1/24 scale Forces of Valor line of tanks they were making. One less company to introduce new tanks in this scale going forward, & one less competing company to drive the market & VSTank.
~ Craig ~
1.PZ754(A) Camo, Gray
2.KV-2(A), Show,
3.PZ753(IR) Gray.
4.KV-1B(IR) Green,
5.TIGER I (IR)"福" mark,
6.TYPE90(IR) Camo,
7.TIGER I(IR) Show Camo,
8.T72(IR)Green
9.L2A5(IR))Show, Camo.
