paint chipping
Old 05-10-2013 | 09:16 AM
Default paint chipping
How do you do paint chipping on a tank.<br type="_moz" />
Old 05-10-2013 | 10:49 AM
Default RE: paint chipping
There are a lot, some of them are complicated for big scales.
I recommned this one for novices, is easy and funnny.
http://www.modelersite.com/en/1154/w...onge-technique
Old 05-10-2013 | 11:56 AM
ausf's Avatar
It depends if it's pre or post paint. I'm assuming you're working with an already painted surface.
This is my take on it, I wrote it about 7 years ago and still use it. There are many other methods, but this works best for me. You can fill with metal, red oxide, rust or all three.
http://ausfwerks.com//techniques/chip/main.html
Old 05-10-2013 | 10:23 PM
AUSF that looks to good. I'd love to be that good.
The sponge technigue dose not come close to your's.
Thanks all for your input.
Old 05-10-2013 | 10:32 PM
Ausf is very talented....he is also an ok tank driver....thankfully his boys are much better then he is.
Here they are at one of our NEAD battledays.
Old 05-11-2013 | 04:02 AM
ausf's Avatar
Too kind guys.
Especially regarding my driving abillty. Although I found a way to level the playing field: I add track links to their tanks at night while they sleep.
Old 05-11-2013 | 02:04 PM
ORIGINAL: colt45101
Sometimes is not the best but the one you can do.
As I told you before there are a lot of techniques, I supposed that if you are asking, it’s because don't know much about that, pigments, oils...etc.
The best technique I know is the hairdryer one, but honestly I think is very much for what we are talking here ( Miguel Jimenez MIG made a terrific Dragon 1/16 with 4 layers chipped)
So back to the beginning, I strongly recommend to begin with simple techniques, if you are looking for a little difficult one, then the salt is a choice.
http://www.modelersite.com/en/481/a-...que-using-salt
The chipped paint using brushes has been useful for years but nowadays there are new techniques with better advance results, but as I commented before, they are more useful for advance modelers and / or 1/35 scale.
By the other hand, remember that WWII American didn’t have chipped paint, but scratches and other kind of marks. The tanks were painted without base paint and cured to high temperature ( like the powdering we know today)
Good luck!
Old 05-12-2013 | 05:50 AM
I referred to the Mig Jimenez blog as well.
I also looked at old copies of the Japanese magazine Armour Modeling.
I used a very fine brush (00) and Testers modeling master enamels, because they dry slower.
I build up in thin layers in this order:
-Dunkelgelg-(lightened with white) to show wear around edges of chipped areas and over areas of green and red brown
-Rust- also resembles the German primer color
-a mix of Gun Metal and rust -to make the exposed steel color
-Steel- to drybrush highlights
Some important factors to consider:
-practice-Spray paint some scrap sprues or unused parts and practice on them first.
-patients-Do one area of the tank at a time and don't over do it. (restraint is hard)
-planning-Think about how the tank was used and what high traffic areas would be.
For example, I imagined how the commander would climb up the ladder and step on top of the turret and climb in to the cupola.
-Avoid creating patterns, or chipping at regular intervals, the chipping process would occur organically or more randomly
I am try to load a picture but I keep getting an error.
Yea RCU!
If you click on my name and go to my profile and click on Gallery, I have some pics of my Panther, which was my first real attempt at chipping.
I did not try it on my Pershing.
<br type="_moz" />
Old 05-12-2013 | 05:57 AM
My take on it is using the sponge technique to chip down to your tanks base layer, then hand paint additional chips over this. Mixture of brown and dark grey gives a nice steel colour, I then very sparingly add flecks of red oxide.
The results:
<br type="_moz" />
Old 05-12-2013 | 06:21 AM
I like, quite simple but effective looking
Old 05-12-2013 | 07:36 AM
Yup, using th&eacute; sponge gives you control but still provides a nice random pattern. Then you can build on this by hand with the base metal colour and red oxide.
