Taigen tiger (early version)
Great work! I really like the tri color and all the details.
A few questions on the model itself. What are the canisters and hoses on the back and rear deck? Are they only on the early model tiger? Also, I'm assuming that's the actual location for the antenna? Was there actually one on the back? I'm currently working on a late model tiger and trying to learn the difference between the two as I go but the pictures are so varied.
Terry
Terry
#32
Well the end is almost in site, paint job is pretty much finished; just the barrel cleaning rods and the sprocket hub caps to do. Since the last update i've completed the pin washes and applied streaking grime, some rain marks and very light rust marks on the sheet steel parts (skirts and exhaust covers). I've also dirtied the exhausts and the muzzle barrel. To finish I've very lightly oversprayed flat earth and added some earth effects on the running gear, the fenders and mud guards.
Next update will be in the display cabinet with a full crew (hopefully).
#41
Hey thanks very much! Basically I had to cut the down to fit. I snipped them at one end then drilled the cable out the tinned the cable down to size ad glued it back in place. Just be careful you don't cut too much off, ruined a cable like that!
#43
Cheers dan! This thread being resurected makes me wish id never sold it (although I did pick up a full option tiger for a bit over a third of what I sold this for) What are snap latches?
