Advice for first R/C tank choice
#103
ah ok...they mixed porsche tiger and henschel tiger lol..
Thank you for this information...
And I presume that Tamiya Tiger I model are without this default?
Last point on Tamiya Tiger I, I've read that turret is only turning on 340°, is it correct?
#104
The Tamiya uses a geared turret ring, driven by a gearbox with a clutch, no stops. The only limit is your wire discipline. If you don't secure the wires neatly and only turn your turret to the left, eventually the wires will twist enough to cause drag. Worse case is you'll pull out a plug.
#105
#106
The only think that limits the Leo 2A6 rotation is the cables like on all the others and the trigger switch on the back of the turret. Although I can't remember how many rotations it limits - I've never tried to go round more than once on mine.
It would be nice if Tamiya retrofit all their older models with similar turret rotation designs. The Leopard 2A6 is awesome.
