Reload this Page >
What is your most wanted RC military model in 1/16
Old 10-14-2014, 04:35 AM
MAUS45
MAUS45's Avatar
Centurion Mark V or IDF Sho't Kal 1973, Sd Kfz 234/2 "Puma", Correct Super Sherman with 105mm gun.
IDF M-48 with 105mm gun!!! Meant to post this the first time.
Old 10-14-2014, 06:07 AM
dgsselkirk
dgsselkirk's Avatar
Originally Posted by Rex Ross
I got a Tamiya Gepard for $100 years ago. I sold it for $200 and felt like a thief who screwed the guy. Somebody kick me.
rex
Consider yourself kicked...twice...
Old 10-14-2014, 09:42 AM
trackmech81
Merkava, Abrams, and T72. Maybe a true lowe hull M60
Old 10-15-2014, 07:01 AM
bigfiver69
I would love to see a Matilda, Valentine, Churchill or Grant/Lee - in other words, some British armor.
There have been a lot of rumors over the years, but if you want one of these tanks I'm afraid you're going to have to scratchbuild them. That's what I did with my Cromwell and Crusader, and once I finish the t34/76 conversion that is on the bench, I'm digging straight into a Churchill, which at my pace is an 18 month project.
Still can't believe NO ONE has produced a British tank...
Shep
Old 10-15-2014, 07:09 AM
Cruiser133
Cruiser133's Avatar
I wonder why there has not been a mass produced M60 yet....
Old 10-15-2014, 07:32 AM
  #31
wsn123
wsn123's Avatar
Russian T-72 or T-90 tank with original engine sound
Old 10-15-2014, 08:02 AM
  #32
Rex Ross
Shep
Are you my long lost brother? I want to do a Matilda next and a Churchill too, but the suspension on the Churchill is not my favorite kind of thing to deal with. When you did your Cromwell and Crusader, did you post photos here? If you did, when was that approximately? I would like to do an archive search to take a look at your stuff. By coincidence, last night I did a search on the Crusader Mk I and Mk II. I like that small turret up front, but the main turret is going to need a jillion bolts, which are the same as rivets to me, and I hate rivets. Maybe I could build "the only one that had an experimental welded turret". I agree about British tanks, ----- actually, all Commonwealth AFVs. And French tanks. And Italian tanks. And Japanese tanks. And ------ it never ends !!!
rex
Old 10-15-2014, 09:40 AM
  #33
SGTMAJMVJ
M60A1 or the ridiculous M103 see video.
Enjoy.
https://www.youtube.com/watch?v=45uZOblVCZc
Old 10-15-2014, 10:04 AM
  #34
Captain Nemo12
Captain Nemo12's Avatar
It's most likely because of the lower hull. From my scratchbuilding I can tell you that in order to fit standard HL coil springs, the lower hull will have to be modified substantially. I did my best to preserve the look of the M60 hull while incorporating a standard HL suspension for my build, but there is always the option of having a torsion bar suspension. In that case, Tamiya or Taigen are in a better position to make one, as I have yet to see a stock HL hull with torsion bar suspension.
Old 10-15-2014, 10:59 AM
  #35
jarndice
Location: Hemel Hempstead,Hertfordshire, UNITED KINGDOM
REX, when I have to fit rivets in 1/16 I use small dressmaking pins, easy to make the right sized hole with a PIN VISE and a touch of superglue on the underside and finish by clipping off the excess pin. I fitted the VOYAGER PE front fenders to a TIGER 1 and finished it off with the pins to simulate the rivets, PERRFECT. shaun
Old 10-15-2014, 01:24 PM
  #36
Rex Ross
Shaun ....
Hey! ---- I do that too. I have three different size heads and I also use small brass brads. The part that I have no patience for is measuring and spacing the rivet locations, drilling the holes, countersinking the holes so that the pins will seat properly, cutting them to length, carefully applying CA and pushing them in the hole without getting them stuck to me or my tweezers. Outside of that I have no problem with using dressmaker pins for rivets. I also use #90, #80 and other small size hex bolts when needed, but they are not cheap, and I am..... my worst case rivet monster was an M3 Lee, a couple of others came close. The ladies at the fabric and sewing store know me by my first name (I wear a disguise when I go in there).
Old 10-15-2014, 03:38 PM
  #37
mondo
Centurion. I'd settle for a crusader but really a centurion is what's needed. The we just needs a T62 and a new T55 kit for the Centurion to blow up.
I'd buy a Matilda senior as well.
Hey, Eric@imex, are you listening make a Centurion mk 5, market it al over but especially Israel and the UK and you'll shift a ton of them.
Old 10-15-2014, 03:56 PM
  #38
bigfiver69
Hey Rex,
I haven't posted here in a while, but I've admired your work many times!
Here are my build threads for the Crusader...
http://www.rcuniverse.com/forum/rc-t...r-3-build.html
And the Cromwell...
http://www.rcuniverse.com/forum/rc-t...ld-thread.html
Hoping to be on the Churchill by the Christmas break. I'm just putting together materials for that build now... I'll post a build thread for sure.
Shep
Old 10-15-2014, 04:18 PM
  #39
Rex Ross
Shep .....
You definitely are the King of the Crusaders. I just crossed that build off of my list ---- I could never come close to your build. WOWIE !!
rex
Old 10-15-2014, 05:12 PM
  #40
bigfiver69
Thanks Rex! You've had some pretty sweet builds over the years too!
Keep your eyes peeled for the Churchill build in December...
Old 10-15-2014, 08:36 PM
  #41
Martellus
a39 tortoise
archer
t1/m6
t29-30 series
char
cromwell
I wouldn't mind a m5 stuart either
Old 10-15-2014, 08:58 PM
  #42
Strato50
Strato50's Avatar
Originally Posted by Martellus
a39 tortoise
archer
t1/m6
t29-30 series
char
cromwell
That point just made me think, that with the steps Taigen took to fit 'unusual' sized or configured gearboxes into their T-34, the realm of possibility for other tanks that wouldn't fit the standard HL-style gearboxes really opens up. Think tanks like any 3-pieces transmission Sherman, Grant, or much smaller tanks like the Stuart, or Japanese tanks... in 1/16 they are all far too narrow for conventional gearboxes, hence some leeway in scale from the scratchbuilds that exist.
Also I'm voting a second time for a production Grant/Lee
Old 10-15-2014, 10:32 PM
  #43
Tanque
Tanque's Avatar
Grant or Lee
Type 97 Chi Ha
Semovente 75/18
Autoblinda ab 41
sWS
GMC CCKW
M24 Chaffee
cromwell
Crusader
Crocodile
Pz Kw I F 'Luchs'
just for starters...
Jerry
Old 10-16-2014, 05:17 AM
  #44
Imex-Erik
Imex-Erik's Avatar
Well I will try not to tease too much but a certain tank listed here will be produced by us Soon.
Old 10-16-2014, 06:16 AM
  #45
Rex Ross
Tanque ....
Which sWS? I must admit I had to do a Google search to find out what that an sWS was, and there were a number of images showing different types of vehicles with that designation.
rex.
Old 10-16-2014, 06:25 AM
  #46
MAUS45
MAUS45's Avatar
Erik, using the word "tease" in a sentence on this thread could be dangerous???
Old 10-16-2014, 07:40 AM
  #47
Imex-Erik
Imex-Erik's Avatar
Yea I think I learned my lesson on the last one I just wanted to let people know we are looking into new stuff and a few here mentioned were/are on the table. That is all.
Old 10-16-2014, 08:12 AM
  #48
cb671
When would be the release date? I'm Contemplating on getting the Torro King Tiger or the KV1 or Sherman (when its released) by next week and maybe I can put that on hold to see whats coming out....This is an Addicting Hobby..just like my Fishing and Archeyr Hobby lol...gonna head to the hobby shop in the morning to get some extra batteries and better airsoft BB's. I hope it's a Japanese Tank so I can do a 1/16 War in the Pacific Diorama
Old 10-16-2014, 08:39 AM
  #49
Tanque
Tanque's Avatar
Rex the sWS configuration I prefer is the cargo carrying version with the canvas cover.
Jerry
Old 10-16-2014, 08:41 AM
  #50
Tanque
Tanque's Avatar
Erik, hints. which page of the thread? which poster's posts??
hints are like Christmas presents...
Jerry
