Metal tracked Jagdpanther problem
I purchased a Jagdpanther with metal tracks,sprockets, idlers, road wheels and hull. The metal tracks wrap up between the drive sprocket and first road wheel. Anyone have or had this problem, how did you fix it? It's the Asiatam lower hull.
Also check the tension. If it is the Asiatam hull you should be able to adjust the tension to help with this as well. You may need to tighten the track tension.
You may also want to remove the tracks and clear every engagement slot of any mold slag or cast seems. While at it work the track ensuring it doesn't bind or kink. Graphite powder can really do a lot to help this.
Hey Joe, PM sent. I'll do a video later, with both my JP and Panther G, and that will give you some ideas. On the G I didn't even try to get rid of the effect, since, as Lostx said, it doesn't affect the way it drives. My G actually drives better with a looser track. And no thrown tracks so far (knock on wood).
Well in my opinion, it's not right and needs to be corrected. None of my other metal tracked tanks do it. I will try some of the other suggestions people have offered. First one will be an idler adjustment. If that doesn't do it I'll keep working on it. It may just be a link that is not flexing as it should.
