Taigen Support AFK until 4/25! Read inside please for details!
Yes and that should be used with caution for airsoft users. If your bbs do not load properly every time that will be a reason there. Goofy as the recoil is it was originally there to help load the next airsoft bb by shaking the hopper a bit. Just remember not to dry fire the airsoft too much if you have one Otherwise enjoy!
Waltersons and I hung out a lot during my trip actually, I have a bunch of news on that one. News thread coming soon, on it now.
Do tell...
#32
Erik, this is probably a dumb question, but as a novice tanker, I don't know the answer: if I want to you use one of my existing Taigen transmitters (I own a Taigen RTR Panzer IV and a Tiger I (kit build)) with one of the new V3 motherboards (on another tank build), do I need any other (electronics) parts? Or can I just somehow configure them to work together? Thanks for explaining how that works.
#34
The switch will need to be soldered like this. Make sure to test fit your switch and make sure the cabling will fit before cutting and soldering your wire.
Plug this into the smoke unit output
#36
Yes, same procedure but the location of the MG is different. Instead of using the toggle like you used to you just hold down the MG button when turning it on, much simpler this way
