Heng Long M41 "Modernization" build.
Go for it have some fun with the ideas and bring them to life. There is no wrong in taking some plausible creative licensing to modernizing an old tank that is still in service and will be for some time to come.
Hi Fsttanks
Looks pretty good. See you went with the cut down HL drivers visors.
Removal of the lifting eyes on the mantlet should make fitting a cover easier, but would be a pain doing maintenance to the gun.
Thanks for the kind words re my builds
Mal
Mal
The gun mantel hooks were removed because the new gun would theoretically have a different method of maintenance uses lifting straps to support the gun barrel. This would be similar to the way it is done on the Abrams and Leopard.
Good observations of the part changes and input on the maintenance. Makes this project fun to think through the “what if’s” of it all.
Basic paint is done and now onto the detail painting. Went with my first paint scheme U.S Armor Sand, Olive Drab and Black breakup lines. Shown here after a few hours with the airbrush. Now to decide whether to leave it as a clean product demonstrator and let it naturally get dirty or add some weathering effects to help start the process?
#31
Hi Fsttanks
Wasn't aware of the use of straps to do gun maintenance on Leo's & M1's - don't often see maintenance apart from barrel cleaning & track bashing. Yes, the ins & outs of maintenance requires a deeper backstory "to sink ones teeth" into.
Really looks the business. The pattern looks very like a MERDC variation. Is that a Radiac mast in place of the aft turret pintle?
Mal
Mal
#32
Hi Fsttanks
Mal
Mal
The small mast is intended to be a SatCom/GPS antenna. It is a bit short but will do until I find a slightly taller one.
#33
Man that looks awesome. The paint does look like 4 color merdec just missing a highlight color.
I don't think a tank would have a short stick antenna for sitcom. that is more of a packset antenna like the 117 has. Vehicles usually have an x wing for satcom on the move.
Its a stick, probably a bit thinner than yours, with an x at 90 degree angels on top. It looks like a propeller that does not have pitched blades. I had one till I traded it for an LOS antenna as I didn't need it, it didn't really work well for amature use turned out. I think you should put an x on top of yours, that would really trick it out man and be correct and people would ask about it.
I really do like what you have done with that tank. Almost make me want an m41 but I really would like an m47. I like the shape of the turret and we have one right out front of our Armory. Also dieing for the m60. Going to go check to see if its up on clarks website next :-)
#34
The small antenna is kind of a "place holder" as it is a bit smaller than I wanted. This type of antenna is more common as a naval antenna used on commercial ships. I know the one you are referencing and will take a look at building one up or finding a "kit" to see how it looks on the turret. I am finding the turret to be a little more challenging to fit parts to cleanly as space runs out quickly and it becomes cumbersome looking. The CROWS was/is one of these issues.
The tank in person really has taken on a tougher, heavier look and feel. It is like an M47 and an M60 had a child. There are elements of both now. To me this is most evident in the new 105 gun and track/sprocket combination. Like you I want an M60 and this little tank project has kinda scratched that itch and is as close as I will be getting for the near future.
I am looking forward to the next phase already adding the new motors, gear box and DKLM Abrams track and seeing just how this M41 stacks up against my other tanks. I am expecting it to be quite the off roader with those upgrades.
#35
Leave the paint as is. I like it. You just have to add an x made out of sheet styrene to the top of the stick and paint it black to make a real satcom on the move antenna. That would look cool on a modern tank. Tanks don't usualy use satcom unless maybe it would be a company commander or BN commander tank. But since this is a demonstrator, they load those things up with every option imagineable to show them off so I would do it.
So where in the southwest are you?
#36
I am in the Inland Empire about 20 or so minutes west of Palms Springs.
#38
If this M41 ends up being the off road monster I think it will, might just have to put an IR until in it too.
#39
LA tank meets every month, we meet about every other month. I go to LA fairly often for the battles and Im down in San Diego, you should come up there if you can on first sundays.
Oh Sep is the San Diego Tank trials. Kind of like a model boat regatta. I defineately want you to come to that, you will enjoy the obstacle course part.
#40
#41
Spent some time adding small detail paint (not complete yet) and light weathering. Decided to go with a light dusting of dirt and grim colored chalk to bring out the "panel line" details and then let the natural uses and abuse take its toll. Considering this M41 is a newly refurbished product demonstrator this light weather made the most sense. The photos below are "staged" as the turret and upper hull have not been secured due to remaining internal work underway.
The photos do not capture the light weather very well, but I thought you might enjoy seeing them anyways.
#42
Buttoned everything up over the last few days and at this point I am calling turret “A” 99% complete minus one antenna. Starting work on turret “B” now. Yes I am working up another turret as I have a new one sitting here and thought I would use it to work up another “modernized” turret with different features. So check back to see the work progress on turret “B” .
No tank is ready though until it has been fully tested. As such off road proof testing has begun and in short order I managed to wear out both #5 control arm axles. The dirt and dust here just ate up the axles in under 45min of running. Good thing I had some spares that were cannibalized off my wreaked M41.
Here are some opening shoots of the off road proof testing. The rocks are part my test course and the M41 will soon be attempting to “rock crawl” over them.
Above is a little teaser of what to expect to see during the M41 off road testing.
#43
Looks Great!!!
#44
While off road testing and suspension tuning is being conducted I have also started to "mock up" and dry fitting of parts to optional turret "B". Turret "B" is intended to be a lower cost and simpler options but still provide substantial improvements to the M41 ability to see, shoot and hit first. To achieve the lower cost, turret "B" will be using an improved 76mm rifled gun with auto loader option vs the 105mm smooth bore. The thicker conformal ceramic turret armor is being replaced with thinner bolt on ceramic turret armor slabs. This will reduce the area protected and the survivability against larger missiles and rockets, but will still provide an increased level of protection vs bare hull against HEAT (signal warhead charge) type man portable shoulder launched AT rockets. The commanders independent DTS have been deleted and will be replaced with a CROWS type system. The CROWS can still be used as a commanders independent sight though with less optic capability. The gunners DTS will be replaced with a larger one to allow for the use of a TOW missile launcher option fitted to the right rear section of the turret. The TOW option is to balance the lack of a larger main gun should there be a need to engage a target out of the effective capability of the 76mm main gun. Smoke launcher have been moved to the mid turret to facilitate use and loading of the optional TOW launcher.
Your constructive input or question are welcome.
#45
Neat ideas, but why not mount the 90mm of the m48 or go really advanced with the isreli 60mm hypervelocty that got retrofited into the chilean m50s. Supposedly it has comoerable penetration to the 105mm.
#47
Initially was thinking 90mm, but the "B" turret is a lower budget modernized option compared to the current "A" turret. The assumption is the country(s) marketed toward would have a fair supply of surplus U.S. 76mm in storage or they are producing their own. A new barrel would add modern enhancements to thermal resistance and improve accuracy. Plus an auto loader option would be easier to install with 76mm ammo (one was designed for the M41, but the U.S. Army chose not to use it for doctrinal reasons).
Installing a 90mm gun would mean a completely new gun system, ammunition and parts supply chain similar to if the "A" turrets 105mm smooth bore was used and the cost, size and weight between the two would be negligible. So it would be better to just go with the 105mm smooth bore gun variant. Plus there are more types of ammunition available for the 105mm smooth bore gun as it can shoot a wide variety of L7 105mm rounds.
The 60mm HVG would be a great option. The only issue is XYZ Corp. that is offering these modernization programs is a U.S. company and in such their customers can use American military aid dollars toward the upgrades as long as the products are made in the U.S. The 105mm smooth bore is being produced in the U.S., so it would not be an issue as is the assumption that the other smaller items are also largely produced in the U.S. The 60mm HVG is not a U.S. made product and aid dollars could not be used toward its cost. Though could be offered at the expense of the requesting country.
The optional TOW system would fill the lethality gap between the 76mm and that of current western 120mm smooth bore guns along with greater flexibility than just an up gun alone.
Thank for the question, it was fun thinking up the answers to the why?
#48
It's out of shot on purpose as I have not yet decided on what I want to use as a muzzle brake, if any at all. The parts below the barrel are from a test barrel off my wrecked M41. Needed to make sure the mods would work before I cut into the new barrel.
#50
That is really cool logic behind it. Totally something Raytheon, BAE or GD could have come up with. Its refreshing to see customization and freelancing on modern tanks that isn't done very much. Whats really cool is you have a lot of knowledge and thought behind it not just a hodge podge of parts thrown together. Your whole story is very plausible. I was thinking what you need now is a company decal across the turret side like Ontrack systems or what ever, with a big white lighting bolt under it or a projectile passing through it like a company logo you know.
