Tamiya Leopard 2A6 Idler Wheel Support
Thought I'd be sharing a 3D printable part I designed for my Tamiya #56020 Leopard 2A6 to help against the Tracks bending the front Hull Corners apart...
Printables Link
Besides the obvious 3D Printed Parts will also require:
1x Set of AFV-Modellbau Track Tensioners ( may work with the stock ones )
2x M3x40mm Metal Spacers ( 5mm OD - Commonly used in DIY Multicopters )
2x M3x45mm Socket Head Cap Screws ( or Button Head Cap Screws )
2x M3 Washers
4x M2x10mm Socket Head Cap Screws
4x M2 Heat Set Inserts
2x M3x20mm SHCS / BHCS ( used while gluing in the Base Part to the Hull )
Plastic Glue that melts Plastics together
Printables Link
2x M3 Washers
Pah co chu puk (11-18-2023)
