In A Pickle!
I'm wondering if anyone can give me a photo or a schematic of a HL tiger airsoft mechanism... I opened up today to do some maintenance and now everything works except the cannon elevation, and bb shooting. I think I messed up the wiring but i'm not sure. I removed the LED in the mantle when I flipped it, and thought I had all the wires done correctly. Iguessed poorly. Any help here?
Ok, I got the gun figured out. but I got 1 little black wire off the gun motor assembly going nowhere and no gun elevation motor. No sound. Nothing. I've tried everywhichway to Sunday with a jumper, and ... Nothing.
ON, CANADA
Brimauster:
Check the MaruiTankGroup archives, someone surely has a pic of the mechanism with wiring in place. If not, ask and someone will give ya the coding fast enough.
Sorry I dinna reply faster, am fighting another bad lung infection... I ~hate~ winter, too cold.
LA
Brimauster:
I have thought I was going to have an answer for you but it seems I am screwed up too. Moving mine around a few minutes ago to take pics two wires came loose and I only know where one of them goes.
I do know that I have 2 black wires from the elev. motor. The smaler gauge one goes to the airsoft switch. the larger gauge goes into the loom of wires that goes to the connector. There is a black wire that I think is for the turret rotation, motor along with a white wire. That leaves me with a red wire that I have no where to go with.......it is the red wire on the far end of the plug that attaches to the upper hull underside.
MD
stang red wire goes to the + side of the motor on the airsoft gun, FWIW the wire with the risitor that goes to the led in the mantlet is not needed for turret rotation or airsoft shooting. You can totally nix the resistor wire altogher.
hope this helps.
Chris Rummel
hope this helps.
Chris Rummel
