 WSN  T34  CONVERSION QUESTIONS!! >
Old 07-26-2006 | 03:13 PM
Default WSN T34 CONVERSION QUESTIONS!!
I am considering a conversion on this model. How are the tracks and gearboxes?
Weak or OK with some care taken while driving?
I can handle the scratch building work but want to be sure the driveline would be up to the task. I plan on using a dual ESC setup and my own electronics for the most part. Will the metal HL boxes fit in with some effort? Aftermarket tracks available? Any info you have will be much appreciated. After building the 1117, Im hooked. Just dont want to drop the cash for Tamiya right now.
DH
Old 07-26-2006 | 03:33 PM
Default RE: WSN T34 CONVERSION QUESTIONS!!
here is a link for tracks and conversion sets for the T34
http://www.tankzone.co.uk/cart/tz_t34.htm
hope this helps
cheers Ian
Old 07-26-2006 | 03:50 PM
ksoc's Avatar
Be sure to check out this site for more info. It is dedicated to RC to Bandai and WSN T34s
http://groups.yahoo.com/group/BigBandaiTanks/
Kevin O'C
<S.C.A.T>
Old 07-26-2006 | 04:15 PM
icecreamslick's Avatar
My Feedback: (9)
You will also want to have a look at this, if you haven't already:
http://www.rctc.co.nz/russian_t34_upgrade.htm
Jason
Old 07-26-2006 | 04:29 PM
Thanks guys, I have seen these but they lend no information on the track or gearbox durability. Anone else have some input? It HAS been an entire hour since I posted this.........LOL.
DH
Old 07-26-2006 | 05:18 PM
ksoc's Avatar
Contact Ethan at DAK - Desert Armor Korps - He is wrapping a T34/76 conversion. He not only is updating to a Tamiya Battle system, but took backdated the entire upper tank to a T34/76 by combining the WSN kit with a static kit. Read through and he does talk about the gearboxes. An e-mail should clear up any other question you have.
www.desertarmor.com General Page
http://web.mac.com/ethandunsford/iWe...20Project.html T34 Page
Kevin O'C
<S.C.A.T.>
Old 07-26-2006 | 05:19 PM
ksoc's Avatar
Sorry it too SO long.........
Old 07-26-2006 | 05:51 PM
Panther F's Avatar
Myself and another member in our tank group have done the conversion using the stock gears that came with the tank. With some reasonable driving around a battlefield that is inside (no rocks, dirt, etc.) and you should be fine. I have about 3 meetings on my T34 with about 5 or 6 battles per meeting and it still hasn't let me down. Use some 280 motors replacing the stock units and the tank is a blast!
Of course, don't expect the durability of a Tamiya gearbox.
Jeff
Old 07-26-2006 | 07:24 PM
The plastic tracks are great. They hold up very well and are plenty strong.
Old 07-26-2006 | 07:31 PM
There's some pics here of metal T34 replacement gears and tracks
http://babelfish.altavista.com/babel...26znewsid%3d41
but they don't seem to be listed on the Tamtoys site[]
Old 07-26-2006 | 07:49 PM
Panther F's Avatar
WOW! I'd like to try a set of those!
Jeff
Old 07-26-2006 | 08:14 PM
I have a T34 that is now converted to use Pershing Gearboxes BUT before that I used the 280 with standard gearboxes... the problem was striping the final drive gears... they did not last long at all (less then 5 min in one case) . ... I would not mind trying those metal gears in one to see how they hold up. could make converting the T34 to Full Option MUCH MUCH less expensive and less time consuming. Those tracks look awesome
Regards,
J
Old 07-26-2006 | 08:24 PM
Here's a 'how to' on the T34 metal gears
http://babelfish.altavista.com/babel...hreadid%3d1306
Old 07-28-2006 | 10:41 AM
Will the HL gearboxes fit in the T34 with minor mods or are they just too big?
Dh
Old 07-28-2006 | 05:46 PM
schutzstaffel's Avatar
check this link , might interest you , you may have to use a translator ...
http://www.rc-panzerketten-forum.com...84498ce&page=1
Old 08-01-2006 | 09:57 AM
Anyone tried the metal HL gearbox in the 34? I have seen the Pershing box squeezed in there which I believe is the same as the Tam. tiger. If the HL is a direct copy of that, maybe the Hl gearbox will fit. Anyone follow that?
DH
Old 08-01-2006 | 11:31 AM
ksoc's Avatar
DH,
The latest is Ethan and his T-34/76 should be at out next battle day in August. A couple of the guys from DAK are making the trip out. Nothing like seeing something in person!
Nice job on the Dodge truck. Can't wait to see it!
Kevin O'C
<S.C.A.T.>
