Progress on my sherman.
Old 05-10-2007 | 12:06 PM
Default RE: Progress on my sherman.
Great detailing Wight looking at your work is really making me want a Sherman
Cheers Ian
Old 05-10-2007 | 12:25 PM
Stern's Avatar
Very, very good work ! [sm=thumbup.gif][sm=thumbup.gif]
Mhmm .. should built a Sherman at next ...
Old 05-21-2007 | 06:20 PM
Hi all.
I have a few more pictures of recent progress.
I reworked the tools to suite the stowages better,not fitted yet though.
I also made some new light and horn guards to a more scale looking thickness.Tricky bit of bending and soldering but got it in the end.
Also the small mesh in the intake next to the rear lights.
The guards are not fixed in place yet as I want to fit the lights first,and then I will need to redo the welds around them as I had to destroy the original welds on the plastic guards.Worth the effort though I think.
Thanks for the comments and encouragements guys.
Stern,looking at your king tiger it would be very interesting to see what you do with the sherman,it would be awesome.
Cheers all.
Old 05-21-2007 | 06:49 PM
hi there that sherman look vere nice sherman 1 favert tanks good luck on iit
Old 06-30-2007 | 05:38 PM
Hi all.Not updated for a while so I thought I'd better.
I bought a really nice tow cable set and fitted the fixings in place.
I wanted to still make it easy to remove the top hull so I arranged it so the front of the cable can be slid out of the front towing eye.
I will fix the cable on properly once painted.
Next up I cut out the rear deck engine cover and hinged it with brass hinges I made.I want to fit a smoker eventually so I did this for that reason,access for filling with oil etc.
They actually seem to work quite well and I have surprised myself with this.
Thanks all.
Old 06-30-2007 | 05:55 PM
  #31
Banned
hey wight that detailling is awesome are you sure thats 1/16 your doing and not a 1/1 youve got tucked away in your garden shed and taking photos of that
just joking mate keep up the good work and keep us posted
Old 06-30-2007 | 07:20 PM
  #32
ArmChairGeneral's Avatar
Thnx for sharing, good job !
Old 06-30-2007 | 09:12 PM
  #33
hdbeast's Avatar
very nice job[sm=thumbup.gif][sm=thumbup.gif]
Old 07-10-2007 | 05:49 PM
  #34
Evening all.
Thank you for the kind words.Very encouraging.
I have been doing more to the tool stowages and have now fixed them in place.The tools will be left off for now though to make it easier to paint,eventually!
Next I need to add welds to the stowages and other areas around the hull that need doing.
Stowages with tools in place.
Stowages without tools.
The back with giant spanner!
Cheers all.
Will post more soon,hopefully.
Old 07-10-2007 | 09:59 PM
  #35
Always nice to see your latest pics and progress Wight
Old 07-11-2007 | 12:12 AM
  #36
Great work Wight[sm=thumbup.gif] some great detailing going on there.
Cheers Ian
Old 07-11-2007 | 03:19 AM
  #37
50Kaliber's Avatar
Awesome work. Bet you wish your wife was as impressed as us... I know mine just gives me that overgrown schoolboy look.
cheers
Con
Old 07-11-2007 | 01:59 PM
  #38
50k,I know exactly what you mean.Although I think sometimes she is very slightly impressed.
Old 07-11-2007 | 02:03 PM
  #39
YHR's Avatar
YHR
ORIGINAL: Wight
I hear you!!!!!!. Kind of the raised eyebrow look and then some comment about skill like that should be used to make furniture for a hobby.
I would like more details on the hinges you have made. They look great.
Old 07-11-2007 | 03:20 PM
  #40
Thank you YHR.The hinges look a little different now as fixing them with superglue was not good enough.I had to pin them in place in the end and had to build them up with solder to make them beefier.The brass I used is very thin to make it easier to bend around the pivot pin.
Basicly I cut out the brass to what I thought was an appropriate shape,on piece with a long central tongue,the other with 2 thinner tongues that would fit either side of the tongue on the other piece.
The tongues were then bent around the pivot pin and the extra length soldered to the back of the hinge plate.The I drilled holes in the plates to accept brass fixing pins,which were then soldered in place.
All this is then lined up on the hull and door.drilled and glued in place.
Seems quite strong now they are pinned in postition.
I hope this helps,my descriptions are not very clear sometimes.I now wish I had taken construction photo's.
Cheers.
Old 07-11-2007 | 03:40 PM
  #41
bhop73's Avatar
Your progress is looking fantastic.
Old 11-24-2007 | 01:39 PM
  #42
StoneColdFreak's Avatar
Okay, Wight, I have a question about your method of drilling the holes for the levers on the filler caps. The angle looks awkward and very close to the armor around the turret ring. I don't know of a drill bit that is small enough and long enough to drill them using a power drill, so the spinning chuck of the drill would hit the hull. It seems like it would be the same when trying to drill out the hinges on the hatches-too close. What are you using? I can imagine just turning the drill bit with your fingers would work fine since it is plastic, but it would be difficult to make straight holes. [] Is there a hand tool that you are using to hold the bit?
Thanks!
Chad
Old 11-24-2007 | 03:12 PM
  #43
Panther F's Avatar
Hey Chad! I'm sure Wight is using a pin vise with extra long drill bits as I do on all of my builds. He has certainly gone the extra mile on his Sherman and it shows!
A very invaluable tool!
Jeff
Old 11-24-2007 | 03:54 PM
  #44
gww
ORIGINAL: Panther F
Jeff
Just to second that comment. Aside from the crank puller for my bike, the pin vise is my favourite tool of the moment. I only bought one recently and I wish I'd done so decades ago. Very easy to control.
Geoff
Old 11-24-2007 | 04:58 PM
  #45
A pin vise...okay, that is good to know! I will have to find myself one of these little jewels. [sm=thumbs_up.gif]
Thanks for the information, guys. It looks like Wight has not been able to update for a while, but I hope to see more of his progress soon. I'm gathering tips, techniques and ideas for my own Sherman build at this point.
Old 11-24-2007 | 05:31 PM
  #46
Very nice work, can you tell me if any Firely conversions exist?
Old 08-01-2009 | 02:33 PM
  #47
Hi guys.
It's been a very long time since I updated this thread and I apologise for that.
I had not done an awful lot to my Sherman until the last couple of months and have now moved on a fair bit.
It's still as yet not finished but as you will see,it's getting there.
Anyway there are quite a few pics to put up so I'll get on with that.
These first ones are from a while back but I did'nt put them up on here for some reason.
Basicly it's power and DMD switches and charging socket under the front hatches.
Loaders hatch
Aiming stake stowage.
Fire extinguisher pull handles.
Finally,some paint!
Stars and the start of weathering.
And with my new baby!
Thats where I'm at so far.Still in the middle of weathering/painting.
At the moment I have been using pastels for for the weathering along with attacking the paint with an abrasive pad and a finger!
I still need to finish the pastels then I will seal it in gloss before any washes etc.Sounds like I know what I'm doing,but believe me I am only copying what others have done on this and other forums.
Sorry for the long post but I thought the best way to update my progress was just to put up pictures.
Cheers,
Steve.
Old 08-01-2009 | 03:13 PM
  #48
Flyn Chris's Avatar
That is some fanstic detailing Steve!
Old 08-01-2009 | 03:34 PM
  #49
Panther F's Avatar
God, you're as bad as I am on my Sherman! Yours just keeps getting better and better with every picture! [sm=thumbs_up.gif]
Old 08-02-2009 | 05:06 PM
  #50
Thank you very much.
Looking a bit different today as I have sealed it with gloss and it looks very dark now.
Cheers.
