Wire for soldering
Old 04-23-2007 | 10:05 AM
Default Wire for soldering
Hi guys,
have read on previous post about the dubious quality of HL soldering and the cheap quality of the wiring used.
How do you determine if wire is good quality or not?
thanks in advance
Old 04-23-2007 | 06:46 PM
YHR's Avatar
YHR
Default RE: Wire for soldering
Genrally speaking the more strands the better the wire. Many fine threads flex better and are less likely to suffer from metal fatiige and break.
Old 04-23-2007 | 08:50 PM
Copper wire works best. It bends more easily than (steel?, tin?) wire and tins (wicks up the solder) more easily without melting the insulation. The *really* nice stuff has silicone insulation, which handles high temps without melting and flexes really nicely, but it's probably overkill for tanks. A light gauge speaker wire would suffice, maybe some stranded Cat5 network cable for LEDs and such.
D.
