JJC Electronics Old Smokey
Hi guys
Anyone tried these yet www.jjc-electronics.com the proportional water based smoke unit looks pretty useful and the sound generators also look pretty good as well albeit marine based but I bet they can be modded for tanks?
Cheers Paul
I reckon with a bit of modding and squeezing I might be able to get one of these in a Tiger 1. I shall do a bit more investigating and let you know. I also like the sound boards, just need to convince them that a Maybach engine might be a good line to move into and expand his market into the RC Tanks
Phil
Phil
Perry
The prices are on teh catalogue about £49 for teh water smoke generator and £30 for the sound module. Looks good.
Any word yet on whether this will work in a tank? The size seems slightly big although a razor saw and a dremel will soon sort that out! (it looks like the large box at the bottom is simply a water reservoir). Any ideas what voltages are used and whether it will be possible to just 'plug it in' to the tanks sound system?
i have phoned emailed and sent self addressed letter to try and obtain old smokey
but no luck, can someone please tell me how to get an old smokey
Looks like it is a 12VDC variable speed humidifier. Did you see that fuse on the control board? And, it looks like he's driving it with a 7Ah 12V batt. That's 7000 mAh. Eat up a 2000mAh batt pretty quick.....
77mm High (about 3"), 72mm Wide (about 2 3/4" ), and 110mm Long (almost 4 1/2"). Won't fit in my Tiger I.
But sure is a sweet idea (provided the tank doesn't get upset with you for pouring water inside it).
Splat
Splat
