pershing project! pic update
thanks fv432
ok im haveing a slight problem with my electronics after the refit......to go forward u have to now pull bk on the stick. and to go bkwards you have to push forwards on the stick??????????? hmm weird ive tried changeing the motor wires every way possible and still the same. this seems to be the way all the turns work in. if you change them round all you get is left and right turns not forwards or bkwards. not sure what it can be????? ive removed the smoke unit and unpluged from curcit boards ectect not sure what else it can be hmm [:@] any ideas appreciated thanks [>:]
does yours have plugs or did you have to solder the wires? did you have the motors out of their gearboxes?
#31
erm nah thay are solderd on but ive just used connecting blocks to join them bk....as have upgraded to metal gearboxes with new blackcap motors
#34
need some help with my electronics. i had all boards out and since the refiting of all electronics there seems to be a problem with the direction signals because when i push forwards on the stick it will go backwards and if im to push backwards it will travel forwards. [sm=confused_smile.gif] i have taken out the connection for the rear lights from the board as thay are not in use and ive also removed the smoke unit. ive tried 2 difrent transmitters and its still the same and ive also tried changeing the motor wires everyway possible but still no luck. [sm=angry.gif] if anyone knows what this maybe? or has any suggestions then please fire away? [sm=idea.gif] also is it possible to fit tam electronics into a henglong? if so any info on this would be a help please
thanks for reading
thanks for reading
#37
so what happens when you red/black to black/red ?
Did you unsolder the wires from the board previously, or is it just a cut 'n' connector job?
#38
i have not yet tried red/black to black/red as i was not sure if this could blow the boards in anyway? nope i have never unsolderd the wires its just simply cut and connecter job
#39
No all it does is reverse the polarity to the motors (so instead of spinning one way they spin the other). You didnt take the motors out of the gearboxes did you (and put them back in the opposite gearboxes)?
#40
ahh i see and yes i did take them out
hmm that explains it then? i cant remember if thay went back the way thay come out tho so i will give this ago [sm=lol.gif]
#42
ORIGINAL: britishtankman
ok here it is
ok here it is
#43
thanks wackywheelz
all is working correctly now. yes bravo i noticed thay would catch on stuff so there are well hidden now lol
#45
I see that the TK-14 board is back in production, which should be great from a power handling point of view (no more cooked boards) as long as it's reliable.
Jo
Jo
#46
All of my S&S boards are RX14's, so yeah, I haven't experienced the goings on with the RX-13, only the non-S&S TK-01
