HL break down
Old 01-04-2008 | 03:35 AM
Default HL break down
ok i was wondering if anyone had a step by step on how to break down the HL TIGER my son turned it up side down and now there is oil comin out of the bottom where the battery is
Old 01-04-2008 | 04:25 AM
Default RE: HL break down
never mind i got it apart but i think my board is fried cause it wont come on and the gun just shoot so do believe the board has fried somehow
Old 01-04-2008 | 04:40 AM
wackywheelz's Avatar
Was it working before you pulled it apart (even with the oil spill?)
I reckon that was likely the smoker unit leaking smoker oil, or possible the airsoft gun leaking its lube (less likely) - neither is terminal, but is messy.
One thing you have to watch when putting them back together is that no wires are crimped between the two halves, and that the turret plug (that the turret loom plugs into) is secured with its screw -- if allowed to dangle it could possibly short.
Another thing is the aerial joiner: convienient for taking them apart, inconvienient because if its not secured its a bare wire floating inside the rear of the tank -- could possibly short on the small smoker pcb etc.
Just chucking around a few ideas...
Old 01-04-2008 | 05:11 AM
swathdiver's Avatar
Welcome to tanking! Heng Long wanted you to experience what real life tankers experienced with their tanks! Such breakdowns will enrich your modeling, electronic and parenting skills!
Old 01-04-2008 | 07:31 AM
The_Stuff's Avatar
check over the board. see if there is any oil on it or the secondary board etc. also you can remove the couple screws holding it down and look at the under side. also check to see if any circuits are blown.
Old 01-04-2008 | 08:15 AM
Oil shouldn't affect the board, being non-conductive. Sure, it might damage/corrode it over time (I mean extended months, or more realistically years)
Something during the de-manufacturing process or putting it back together has crimped or shorted one of the boards, usually you just lose a function.
Old 01-04-2008 | 02:24 PM
ORIGINAL: hpifocus
If your board is fried you can get them at Mato Toys or Tankzone.------BIGMIG
