Heng Long Hardware
ON, CANADA
Hi Guys
I have a question about Heng Long screws. I have been busy over the last month or so disassembling tanks and painting them so I can detail and weather them over the long cold winter months here, anyways on to my question.
When I take apart my tanks I usually use a #1 Phillips screwdriver but have noticed that on some tanks that I need a #2 because the #1 seems to be chewing up the heads on some of the screws? You would think that they would all be the same, Is it possible that the heads on some of the screws are slightly bigger or smaller from screw to screw?? I'm assuming that the metals they use are soft and somewhat lower quality to keep production costs down? Just weird things I have noticed after taking apart 10 tanks,lol. So was wondering what size screwdriver you guys use for the most part?
And another question while I got your guys ears, I know what size screws are used on the sprockets and what size for the Hulls but does anybody know the size thats use to hold the small plug receptacle on the tops of tanks turrets and that small little board thats attached to the turret ? There small thats all I know,lol but I guess not as small as the screw that holds the antenna wire on
Cheers guys
Jeremy
Cheers guys
Jeremy
ON, CANADA
hey guys
I just removed a turret motor from a Panzer IV and did notice that one of the screws dis have a bigger head then the other 2. had to switch between 2 size phillips.[&:]
WA
Its probably a combination of poor quality metal, and poor tolerances. Chinese manufacturers aren't known (at least in my book) for spending a lot of time or money on small parts that aren't necessarily critical. If it can be installed once, it's good enough.
Just another reason a HL doesn't cost what a Tamiya does.
I had a crossthreaded screw into one of the motors on my Panzer III, but hey, it was like $140!
Could be the screwdriver and or the quality of it as well. Try a different brand.
JAT
JAT
ON, CANADA
ORIGINAL: Wozwasnt
They seem to use whatever screw comes out of the box first.
seems like it huh, thats exactly what I said to myself this morning taking apart a panzer 3 " they use whatever screw they find first "
ON, CANADA
ORIGINAL: Panther F
JAT
JAT
ORIGINAL: Wozwasnt
Jeremy
I don't have a clue what size most of them are. When I put my tanks back together, I always end up with extra's
Heck I will use anything that is even close to the orignal size, never really paying much attention to them at all!!!!!
so I dont think its quality.
