ZIMMERIT PATTERNS
Im getting ready to zimmerit my jagdpanther, can anybody tell me what options i have in the pattern of zimmerit for the jagdpanther.
This is the pattern they give for the early jagdpanther, i have seen this on several jp's and think it looks ok, but just wandering if the later ones had a different pattern.
Thanks for the link uhu
AS Fireflykeith correctly says Jagdpanther had the "block pattern" this was the only pattern used on Jagdpanther and was applied to all early models possibly some mid models and wasn't used on the late models
Hi FireflyKeith
Another interesting article
http://www.panzerworld.net/zimmerit
look at patterns 1 and 5, some early Jagdpanthers were zimmerited with the pattern 1 although the majority had the small squares pattern.
Cheers
Jose
Cheers
Jose
Scat Patton the pattern on your Panther is correct for a Panther built by the MAN factory but would be wrong for a Jagdpanther
Firefly go with 5 this is correct and very easy to do using Milliput all you have to do is with a very blunt Stanley knife blade run your lines horizontally and vertically a very good book to look at is "Combat history of schwerepanzer abteilung 654" this covers the divisions Fredinand and Jagdpanthers
