 Tamiya electronics question >
Old 09-26-2008 | 11:04 AM
kclank's Avatar
Default Tamiya electronics question
Does anyone know the function for connector CN5 on the DMD-T03. If you know the answer do you also know how to access it (receiver lever throw or?)
Old 09-26-2008 | 11:30 AM
SCAT PATTON's Avatar
Default RE: Tamiya electronics question
I dont know, but what ever you do - do not plug the TBU emitter into it; frys the bulb! [:'(]
Old 09-26-2008 | 01:08 PM
I believe it is included to trap an inattentive modeler.
But for sure, do not plug lighted head lamps or the flashing machine gun into it, as it will fry them too!
John
Old 09-26-2008 | 07:25 PM
kclank's Avatar
yeah one of my buds did that too. i guess it is a probe and guess situation. ok just seeing if there was some intelligence out there (sic).
Old 09-26-2008 | 07:48 PM
Might be worth opening up the MF unit and tracing the pins to see if their hardwired to power, inputs directly to the processor, or switched by FETs.
I'd consider opening up my Sherman MF unit, but it's stuck to the chassis with some seriously nasty double-sided tape.
D.
Old 09-27-2008 | 08:26 AM
ORIGINAL: darkith
D.
When I removed mine from the bottom of the Tiger, the plastic box had cracks all over its body. That tape is really nasty.
Old 09-27-2008 | 09:30 AM
Had similar experiences with that tape, though rubbing alcohol kinda helped with DMD removal and prevented any damage to its case. Now use little self adhesive velcro squares found in places like Walmart etc.
Old 09-27-2008 | 02:31 PM
ksoc's Avatar
S L O W A N D S T E A D Y pressure is what it take so remove the DMD's. You can't do it in 10 seconds. It takes a couple of minutes.
I've also switch to Velcro dots to securing the electronics.
Old 09-28-2008 | 08:41 PM
I always thought CN5 gave whatever voltage the battery was supplying as I think I used my multimeter to measure it some time back. I even hear do f someone using itto power some head lights on a Tiger or KT. Not sure though, my memery about it is very vague now.
Old 09-29-2008 | 07:09 AM
borealis's Avatar
Maybe it could drive a smoke generator?
Old 09-29-2008 | 10:08 AM
grompix's Avatar
I use it to power a headlight on my Panther.
Old 09-29-2008 | 11:44 AM
kclank's Avatar
Yup straight through power. i checked it this am. so anything that you can use pure power for guess can be driven with it (can't quantify amp load). I also was thinking of smoke generator as Borealis suggested.
