Metal Jagdpanther tracks at Mato
RE: Metal Jagdpanther tracks at Mato
Excellant , ready for the Panther as well when it comes out. Metal tracks make such a difference I consider them mandatory. Really looking forward to adding a panther to my collection.
I wonder if the panther tracks are the same as those marketed before for the Pantiger with the metal wheels? I have those and would just swap them over.
AB, CANADA
I was told by Murphy the old track would not work, but I am sure if you swapped the drive wheels, they could be made to work. I was going to find out, but now I don't have too
This set is different and especially for the JagD and upcoming Panther.
The track looks the same, probably a different length so if longer one would need more links. The sprocket design changed some, the original looks better with the cap over the screw hole rather then open. Has there been any word on a new Panther release utilizing the Jagdpanther's lower hull? If that's in the works I'd pony up for one of those!
ORIGINAL: YHR
It is true the new wheels can be replaced by the old ones and then the old metal track can be used. the difference is the width between the drive teeth. i am runnng the old config. on my new JagdP.
Swathy you did miss something , I'm surprised at you ! lol Yes a new panther IS coming out using the new jagdpanther hull and it looks cool.
