Tam Leo 6 wiring
Tam Leo 6 wiring
Guys, how did you put wires in Leo 6? I find it difficult to close the turret without cuttung some wires, especially 4 thick wires to gearboxes.
Any pics of the layout?
Best regards,
Eugene
1 Post
RE: Tam Leo 6 wiring
Hi, Iknow this wont help you any but Ihad the exact same problem and was not happy about cutting any wires. Eventually I got them to fit quite well by pure trial and error... but it did take me a LOT of trial and erroring!!
Good luck, Rich
Good luck, Rich
Don't cut them!
Mostly it's trial and error like SB mentioned. Plus, I left the front armor pieces unglued (they stay on with friction) and can see inside the turret, looking for places that are obstructing the upper turret from sitting properly.
The two biggest problems I found were wires catching between the top half tabs that sit on the bottom turret half and second, wires going over the battery. I don't have the flash unit in it in these pics, but it does fit with a slight rearrangement of the wires on that side.
FL
I had the same issues. After a lot of tinkering i made it work, but they would get shifted out of place with every turret opening or battery change. mini zip ties help though.
I eventually got annoyed and just moved the batteries (dual 3500mahs) to the hull. Now i have all the space in the world in the turrent and its great. Downside is i had to remove the speaker but i found it cheesy anyway. Id rather hear the real engine ;p
ORIGINAL: CapnCrunch43
Don't cut them!
Don't cut them!
NIceand neat layout!
Too late! I am very impatient so I cut the cables w/out waiting for the replies. Now I will put DEANs connectors (from ETOarmour)on the wires (only 2 needed)+ I will replace the bulky Tam connectors on the battery (only one connector required). Original connectors are literally devouring the space.
