 Tamiya Pershing in progress... >
Old 02-20-2010 | 11:56 AM
yellowshaker's Avatar
Default RE: Tamiya Pershing in progress...
Thanks Blitz! Here's the latest photos. Still not finished...but getting there. Only one picture is close to the actual color...I am planning to buy a new camera. lol
I am working on fitting the brackets for the turret dust cover and installed the periscopes from eto. It's still coming along.
ID:	1383026   Click image for larger version
ID:	1383027   Click image for larger version
Old 02-20-2010 | 03:34 PM
Yellowshaker,
You have come quit away since joining not too long ago. I envy your tanks. Where did you find that paint " mr surfacer". It does an outstanding job of simulating cast parts. Thanks for sharing.
Jim
Old 02-20-2010 | 04:56 PM
Wonderful repaint. I am doing the same tank,and have finished the construction and painting.
I did spring for the pewter A/M periscope guards,after deciding my handmade ones weren't as good.
What RC rig do you use? I have an older Futuba 4 ch,which uses a dedicated nicad pack for receiver power.
There isn't enough room in my hull for this set up.[img][/img]
http://img.photobucket.com/albums/v4.../builds/30.jpg
Old 02-20-2010 | 05:00 PM
Thanks alot 1Sgt. I am trying my best to learn as I go with each tank. If not for this site and the good folks here, I'd be lost.
Tankcarl, the Mr surfacer was purchased on ebay. Was not expensive and a little goes a long way. It is easy to work with and being that it is applied with a brush, ou have alot of control over where it goes.
As for the rc system I am running the Spectrum DX5E bought from rctankwars.com w/BR6000 receiver. It's a nice setup and I have no problems with it.
Do you have a diret link to the pic you were trying to post?
Old 02-20-2010 | 05:15 PM
DONE!
Old 02-20-2010 | 05:20 PM
  #31
Your tank looks really good too! I'm working on a test fit for the dust cover and will try to post pictures if I get it together this evening. I'm also looking to install the Turnigy chip this weekend.
Old 02-20-2010 | 05:46 PM
  #32
Don' t forget to drill a hole through the engine lifting hoist mounts on the loader's side of the turret.
And add a loop on the square pad above the side rack on the TC'c side of the tank.
http://img.photobucket.com/albums/v4.../builds/29.jpg
Old 02-20-2010 | 06:03 PM
  #33
OK, now you lost me...
ORIGINAL: TankCarl
Old 02-20-2010 | 07:55 PM
  #34
I got the dust cover on, but not thrilled with it.I am going to look for a better material to use where I can get it to conform a bit better. it will do for now though.
ID:	1383287   Click image for larger version
ID:	1383288   Click image for larger version
ID:	1383289   Click image for larger version
ID:	1383290   Click image for larger version
Old 02-20-2010 | 08:19 PM
  #35
ORIGINAL: yellowshaker
I think he meant these:
Your Pershing looks good! If you ever find a suitable fabric for the dust cover, please share.
Old 02-20-2010 | 08:44 PM
  #36
Thanks Googly...I will see what I can do with that.
As for the cover...yea, I used a plastic bag which is not exactly what I was looking for. I wanted to try it though. I saw a build on another forum and the guy said he used cling material of some sort...I am not sure what he meant though. The material has to be paint friendly and platic bags are not. Next shot will be with material from an old bandana.
I started on the weathering and accessories...
ID:	1383331   Click image for larger version
ID:	1383332   Click image for larger version
ID:	1383333   Click image for larger version
ID:	1383334   Click image for larger version
ID:	1383335   Click image for larger version
Old 02-21-2010 | 11:12 AM
  #37
@Googlydoogly.
Exactly. Those mounts were for a jib crane attachment,so engines and such could be self extracted. I am thinking a good material for the mantlet cover could be a fine weave cloth. Cnavas does look " coarse,so at 1/16th it would fill the bill. The only downside it would be stiffer,as the cloth is 1:1,and the scale of the tank is smaller.
I also added some tie down loops on the top of the rack,on the side of the turret.
Old 02-21-2010 | 01:58 PM
  #38
Tankcarl, any chance you have better pics of those modifications? I can't make them out very well....
ID:	1383882   Click image for larger version
ID:	1383883   Click image for larger version
ID:	1383884   Click image for larger version
Old 02-21-2010 | 08:34 PM
  #39
Your requests are my obsession;
loops on side basket
fender tie downs,less on driver's side,BTW
Retaining chains for cover handles
Horn wire
Using the tie downs
Other mount, and drill out the ends of the track pins.
Old 02-21-2010 | 08:47 PM
  #40
Dude, you rock!! Thanks a lot for the extra work LOL
I got tired of working on the tank and decided to actually runit a bit...Sooo, I video taped it too...And uploaded it...and ...well you know the drill.
http://www.streetfire.net/video/Pers...ite_736896.htm
Old 02-21-2010 | 09:04 PM
  #41
Nice video of your "Fireball " running.
I was lucky,I assembled mine,and knew the barrel was in the recoil stage. After painting,and testing everything,The gun came out to normal "in battery" positiion,
and I had a nice clean area where there would be no paint,on the sliding surface of the gun.
I plan on making a rolled tarp for the right side of the fender,with appropriate simulated straps holding it in place.
On the photos I have seen of production M-26's there were no loops on the drivers side front stoawge box.
Old 02-21-2010 | 10:02 PM
  #42
So I messed up again? lol That figures...I though they had the tie down there too. Well, easy to fix. I can't wait to get this thing out in the right terrain!
Old 02-21-2010 | 10:40 PM
  #43
SoulAssassin's Avatar
Excellent tank Shaker!
Old 02-21-2010 | 10:48 PM
  #44
Choochoo187's Avatar
Thats Awesome! great video YS . i even digged the dogs.  Nice looking Tank Sir.
Old 02-21-2010 | 10:50 PM
  #45
Thanks fellas! I cut the scene where my real puitbull almost ate the poor Pershing before it ever got to a battle day. lol
Old 02-22-2010 | 12:11 AM
  #46
I just found this site and wasn't sure if any of you had seen it beofre. Alot of interesting pictures and information on here...
http://www.ipmslondon.ca/old%20site/...cles/id25.html
And I did a bit more work..details details...lol
ID:	1384422   Click image for larger version
ID:	1384423   Click image for larger version
ID:	1384424   Click image for larger version
ID:	1384425   Click image for larger version
ID:	1384426   Click image for larger version
ID:	1384427   Click image for larger version
Old 02-22-2010 | 12:54 AM
  #47
Rebellion13's Avatar
So I take it your liking your pershing? Man the sounds are really impressive, that's the first time I've heard the tam pershing, wow. Makes me re-think about getting a sherman. We should have a sticky so people could post their video's just for the sounds lol. Thou shall not covet thy neighbors tank [sm=cry_smile.gif]
Cheers,
Wade
Old 02-22-2010 | 12:59 AM
  #48
LOL, I covet thy neighbor's tank!!!!!!! HAHAHA!!! I am stoked with the Tamiya Pershing. I keep telling myself to stick with the HL's...cost efficiency and all, but..well...I think I have turned to the dark side!!! Trust me, once you have one the addiction only gets stronger. I'm waiting for the T-81 tracks from Kenny Kong to arrive so I can make this tank almost accurate lol.
P.S. The Sherman is the ONE tank I want above all...I'm up to three tanks and still not one Sherman...
Old 02-22-2010 | 03:29 PM
  #49
http://www.streetfire.net/video/Tami...-BW_736705.htm
Yellowshaker,
Great Tank and video. Loved the music soundtrack as well. Brought back memories. Thanks again.
Jim
Old 02-22-2010 | 11:40 PM
  #50
Thanks man, I'm trying hard with this one. I have more detail work to do thanks to Tankcarl. lol I started some this evening.
ID:	1384974   Click image for larger version
ID:	1384975   Click image for larger version
ID:	1384976   Click image for larger version
ID:	1384977   Click image for larger version
ID:	1384978   Click image for larger version
ID:	1384979   Click image for larger version
